97 F150 w/12mm Lugs
Old Jun 26, 2003 | 09:10 AM
Fifer's Avatar
97 F150 w/12mm Lugs
New person here.
I have a 97 Flareside with original clearcaot rims. My question is similar to Shepdog's:
Will 2003 Ford F-150 Crew Cab rims fit on my 97 w/12mm lugs?
If the lugs are not the same, Ford does not recommend using them. Is there any other options?
Thanks much.
Old Jun 27, 2003 | 07:02 PM
powerstroke73's Avatar
Yes they will swap fine, you just need to use your current 12mm lug nuts.
Old Jul 7, 2003 | 12:42 PM
Fifer's Avatar
Thanks, Powerstroke!
Would I need to put a washer under the lug?
Old Jul 7, 2003 | 10:47 PM
No the stock lug nuts have the washer as part of it.
Old Jul 8, 2003 | 11:32 AM
2stroked's Avatar
One other thing you might want to check is which 12mm lug nuts you have. As I recall (having had a '97), some early 97's had a lug nut recall because of a heat treating problem. The "bad" lug nuts were silver in color. The replacement nuts were black. If in doubt, check with your dealer. Otherwise, everything should fit just fine.
