Bullit wheels on a 150
Hi, I'm new here and you guys seem to really know you 150 info. I am looking for a pair of front rotors for my '98 150 that have a 4.5 inch bolt pattern like the mustangs. Does anyone out there know of a manufacturer that sells truck rotors with different bolt patterns, or do you know of any other ford rotors that will interchange? I want to run a set of Bullit wheels on my truck.
Thanks for the help.
Your rotors will not be the biggest problem because the studs are mounted into the wheel hubs - not the rotors. The rotors just have holes for the rotors to slip over them. Replacing the hubs with the bullit pattern and then finding rotors with the correct diameter, width, bolt pattern, etc. will probably be a major pain. Then again, have you checked the back spacing on the bullit wheels? It might be wrong for an F150 too. Good luck.
