Parking Brake 99 F150 4X4
Old Mar 10, 2003 | 07:13 PM
Gusepi's Avatar
Question Parking Brake 99 F150 4X4
My parking brake could use a good tightening. Is there a fairly easy adjustment I can do? If so how?
Old Mar 11, 2003 | 11:30 AM
Richard D's Avatar
First step is to check the rear brake pads or shoes depending on which you have. This may be an indication of low material and you may need new pads. After that has been done if all is fine the rear brakes may need adjusting.
Richard D.
https://www.f150online.com/galleries....cfm?gnum=2479
Old Mar 12, 2003 | 12:59 PM
hcmq's Avatar
the parking brake cables like to strech over time.
if you have rear drums do what richardd says. if you have rear disks I doubt it is due to wear because the parking brake has nothing to do with regular braking.
look on the back of backing plate. you should find a little rubber grommet at the bottom towards the ground pop that out and there is an adjusting wheel in there. don't adjust it too tight as it will cause drivability concerns.
Old Mar 13, 2003 | 02:01 PM
Gusepi's Avatar
OK Thanks
I have the rear discs. So it sounds like a brake cable is worn.
