brakes questions email me
Old May 10, 2001 | 02:52 AM
fordtec2001's Avatar
Post brakes questions email me
if you have brakes question you can email me and i get back to ya with a answer or as best i can answer brake questions as best as i can
quentin_001@msn.com
Old May 10, 2001 | 04:07 PM
Bors's Avatar
Post
I have a couple of questions.
I have a 1999 F150 2x4 supercab with 4 wheel anti-loc disc breaks. I have done plenty of break jobs on standard disc breaks but never on an anti-loc system.
When I picked up the breaks (Wagner semi-metalic) the guy behind the counter told me to open the bleeder valve when compressing the pistons to prevent damage to the anti loc system.
He also said that since the parking break was part of the rear calliper and that a special tool was required to compress the piston. He letting me use one free however is there anythig I should be aware of?
The Hayne's book does not mention any of this.
Any suggestions/Guidence would be greatly appreciated.
Bors
Old May 11, 2001 | 12:20 AM
bohunter's Avatar
Post
I tried to e-mail you but it was kicked back. I am going to change the rear disc pads this weekend. Is there anything I need to be aware of, anything tricky? I did the front with no problem but I never did rear discs before, always drums.
Old May 11, 2001 | 12:27 AM
Post
just do one side at a time nuthing tricky if u done the fronts you should have no probs with the rears
Old May 13, 2001 | 02:48 AM
Post
he right in a way you can damage anti lock sytem and its easier to compress the piston back in when changing pads
you should be ok doing the brakes if you done them before good luck
Old May 13, 2001 | 02:56 AM
f150freak's Avatar
Post
here is a question for ya. Why does it seem that the front break pads dont last very long? I just did my front brakes Saturday beacuse the warning clip on one side started sqeeling friday. I only have 28,800 miles on the factory brakes. From what I have read so far it is pretty normal for them to wear out at this point.
Old May 13, 2001 | 07:48 PM
98SCREAMER's Avatar
From: Houston, by way of every major city in America.
Talking
Hey f150freak,
Mine lasted to 32,000,I guess I got good use out of them. The rotors started warping at that mileage,and the pedal vibrated like it was made by Homedics ,,,,98
98 F-150 4.6 Litre XLT2wd Ext. cab
Yokahama AVS/ST's,,too noisy
prarie tan/tan int.
K/N gen.II fipk
custom dual exh/gibson rectangle tips/rear exiting.
color matched snuglid
Superchip!!!
Clear front corners
Speedglo gauges w/carbon fiber overlay
Carbon fiber Grant styling ring wheelcover
Stillen Quad light air dam,with Pilot PL-240 driving lights
Billet third brake light cover/oval pattern
Euro taillights,with APC red bulbs
Cobra 75WXST cb w/weather alert
Kenwood cd w/Radio Shack speakers,and Soundstream P203e amplifier//Single 10" sub
Viper alarm
On the waywheels,tires,Proglass shaker hood,Steel Horse C5 leather seat
Come see my new pictures@ www.my-f150.com
WOW,what a cool site!
FENDER GUITARS ROCK!!!
I just "wish" it was lowered
Old May 14, 2001 | 03:07 AM
KYFordFreak's Avatar
Post
This is going to sound very very stupid of me...but, how can you be 100% sure that you have 4-wheel ABS. I know I can feel the front lock and unlock on a panic stop. I thought that since the front does it the back probably should too as I know from my dads truck that Ford started using ABS on the rear first. Also, I wanted to make sure that you have to open the bleeder screw when chaning front pads. I never opened the bleeder on any other vehicle I have had and no harm came to them but, of corse they were non-abs too.
Old May 14, 2001 | 10:24 AM
2winturbo's Avatar
Post
Here's my question:
I have a 97' F150 with rear ABS/ drums. On more than one occasion I was traveling a little too fast for traffic and had to slam on the brakes! To my surprise the rear end locked up and kicked out to the side a little until I let up..I have also notice in the snow I could lock up all four tires and slide. How can this be with ABS even if it is only in the rear. I never felt any pedal vibration. Is my system working correctly? The ABS light only comes on for a second when I start the truck but then it goes off after the system check is completed. I would apprciate it if you could help me out. I would rather not pay the dealer $75 to tell me my system is working fine.
Old May 14, 2001 | 06:21 PM
2000 F150 4x4's Avatar
Cool
2winturbo: My ranger had rear abs. It got to be intermittant as the truck got old. There was a big difference when it worked and when it didn't. The rear end never came around when it worked, but would when it was off. And my light did stay on when it wasn't working.
2000 F150 XLT 4x4 Short Bed. Amazon Green, 5.4L, SuperCab, ORP, Tow Package, Sliding Rear Window, Electronic Shift, Keyless Entry, LT265-70-17 Tires, Clarion Pro Audio, Herculiner Bedliner, Air Silencer Removed.
1994 SVT Mustang Cobra. #1032 of 6009. Black coupe with black leather int., 3.73 rear, Bassani Exhaust, Aluminum D/S, Bridgestone RE-71 255-45-ZR17
My Home Page
Old May 21, 2001 | 11:16 PM
aypstony's Avatar
Question
I was going to do my rear brakes (drums and shoes). I need to know what "spring release" tools are necessary to make it an easy change. The haynes manual mentions a couple tools, but I need clarification....Thanks
1997 F-150 4X4 XLT Supercab
Black w/ Gray two tone and flares
5.4L Triton
3.55 LS
Gray interior w/ Captains's chairs
6 CD Changer
Class III Towing
285 75 16R BFG's
