Rear disk conversions
I am looking to convert my 98 XLT to rear disks.Can I use the hardware from a navigator
[Rotors,calipers,and master or do I need to buy an aftermarket set up...
it will depend on if you have the same axle and bolt pattern as the navigatory. IF you do, it should be an easy swap. Also check the master cylinder and brake booster to make sure they are the same size. You may need the lincoln parts also.
Rob K
What about using the rear end parts of an expedition? If you go ahead with the project, let me know about your findings.
My Ride: 1998 F150 4x4 Lariat Supercab Flareside 5.4L in Oxford White/gold, ORP, Tow Package, 3.55 Gears.
Modifications: K&N FIPK, Stepshield door sill protectors, Performance Accesories 3" body lift, Lift Lips and Daystar front anti-sway bar polyurethane bushings.
Photos at: http://www.communicomgroup.com/jmtruck
