real axle seal leak
My 1997 ford f150 4x4 is in the shop. The ford dealer reports finding the left rear axle seal leaking. The real damage was caused to the breaks, which now require about $500 to replace the drums, and break shoes including labor. Has anyone experienced that problem? My truck is driven on the highway and has only 37000 miles on it.
Thanks,
Lou
Thanks,
Lou
That sounds suspiciously expensive.
Axle seal leaks frequently contaminate the brake lining material, but seldem result in damage to the drum. The right (er, wrong) amount of axle lube leaking on a brake can cause it to drag and overheat causing heat spots or checking (cracking) of the drum -- but that is somewhat rare.
Consider obtaining a second opinion from a trustworthy mechanic on this one.
The 'official word' in lube-contaminated-lining repair calls for the replacement of the lining -- but the 'whisper-fix' involves washing with solvent (like the product "Brakleen") and detergent/water -- as long as the lining bond to the shoe table is sound.
Here it is a year after my last post -- and I just returned from the dealer after having a left-rear axle shaft seal leak repaired.
I first got a whif of hot oil at a rest stop while towing my trailer a few weeks ago -- and did the 'oh-m-god' check of the right-hand head gasket for drips on the exhaust manifold.
Seeing none -- and not being able to find the source, I forgot it.
Last week, I rotated the tires, and discovered that lube had been slinging off of the rotor and all over the wheel/tire -- contaminating the parking shoes to boot.
Well, the dealer fixed the seal, de-greased the shoes and pads (crazy parking brake set-up on these disc-brake rears), replaced $70+ dollars of synlube/friction modifier, and sent me on my way sans charges (I'm still under warranty).
My dealer, Simmons Ford -- Vicksburg, MI, has been taking very good care of me -- which keeps me driving 40 miles round-trip to their shop.
So...
...if you get a whif of hot oil, check out the rear axle-shaft seal for leakage, and be suspicious of $500 brake jobs due to lube contamination.
So...
I just had this same problem fixed on Saturday. Total cost to me was $380.00 (with new Raybestos Plus brakes on the rear). My truck is at 79,215 miles right now. This is the first problem I have had with it.
Rick
Clinton Township, MI.
Rick
