Po133 O2 Sensor Circuit Slow Response (Bank 1 Sensor 1)
Old 11-22-2002, 09:37 AM
firmin70053's Avatar
Question Po133 O2 Sensor Circuit Slow Response (Bank 1 Sensor 1)
Does anyone know if this is really an O2 sensor and if so which one (where can I find it)?
David
98 F-150
4.6 liter
Old 11-22-2002, 02:29 PM
hapynzap's Avatar
Sounds like it.
How many miles on your truck?
Old 11-22-2002, 02:39 PM
92000
Old 11-22-2002, 03:09 PM
hapynzap's Avatar
I read somewhere that you should replace all your O2 sensors (4) at 100,000.
might be an easy fix
Old 11-24-2002, 12:17 AM
Chewy20's Avatar
On my '97 5.4L bank1, sensor 1, is on the passenger side closest to the engine. I had the same code and replaced just that sensor. As for replacing them all, at $50 apiece, I think I would just replace them as needed. The one I changed was a serious "bitch" to get to.
Old 11-24-2002, 04:44 AM
wmcnally's Avatar
firmin,
I was just reading somewhere that when you get that code (slow response)
you should replace BOTH O2 sensors in that bank. In your case Bank 1 sensors 1 and two. If you don't the PCM may read the old sensor as being slow (compared to the new one)
Good Luck,
Bill
Old 11-24-2002, 08:59 AM
TexfordD's Avatar
i believe the...
up stream sensors are the ones that take the beating and the downstream sensors(past the cats) rarely need to be changed
Quick Reply: Po133 O2 Sensor Circuit Slow Response (Bank 1 Sensor 1)
