Check Engine Code PO455
Old Oct 21, 2002 | 06:21 PM
mgalluccio's Avatar
Question Check Engine Code PO455
Check engine light on my 2000 F150-V6 came on the other day. Stopped by the neighborhood AUTOZONE and determined it was code #PO455. The narrative reads:
PCM HAS DETERMINED THAT THERE IS A LARGE LEAK IN THE EVAPORATIVE EMISSION CONTROL SYSTEM.
Question: What is the Evaporative Emission Control Sys. and where might I begin troubleshooting?
As always, thanks for the help.
Old Oct 21, 2002 | 07:13 PM
TexfordD's Avatar
check your gas cap...
then your charcoal cannister
Old Oct 21, 2002 | 07:32 PM
hcmq's Avatar
yup gas cap.
the evaporative system takes fumes from the gas in your tank and re-cycles/burns them so they don't leak in to the atmosphere
just put your cap on tight re-set your computer and away you go. if you don't want to re-set the pcm it will take a few cold start cycles to clear the mil
there is a remote possability that a line came of or is cracked coming off the charcoal canister. have you changed headlights or done anything under the hood lately?
your "O"-ring on your gas cap might be warn.
good luck-
Old Oct 22, 2002 | 05:41 PM
mgalluccio's Avatar
Thanks,
I was thinking along the lines of the gas cap or something of that nature.........(EVAPORATIVE was the giveaway). I will check these items and repost if and when it corrects the situation.
Thanks again!
