This has me baffled!
Old Sep 26, 2002 | 05:53 PM
Silent Bob's Avatar
Earlier this week I was driving to work and just as I hit the back gate I noticed the oil pressure had dropped off and the light came on along with the water temp light. I didn't here anything different in the engine, pulled over after I got through the gate and checked the water and oil. Everything was where it needed to be. I started driving again and the oil pressure gauge tried reading again. After the truck sat for a couple of hours, I checed the oil and coolant again. Both were in the normal range. I started the truck and everything went back to normal.
Today (just two days later) I had the same thing happen. Iwas like deja voo. The only difference was that I had different clothes on.
If any one has a clue, let me know so I can solve this mystery!
Old Sep 26, 2002 | 05:59 PM
ROUSHFAN-1's Avatar
sounds like an electrical problem....the oil pressure gauge is essentially an idot light on/off operation..... doesn't read pressure ...with both gauges going whacky...im thinkin' electrical..your engine should be o.k. ....get it checked ..it's still under warrenty ..correct?
Old Sep 26, 2002 | 06:03 PM
Silent Bob's Avatar
Warranty was up 30k mile ago. This is a 97 4.6L. This will suck if I have to put money toward this, it will take away from the mod money. (pun intended)
Old Sep 26, 2002 | 10:09 PM
rfaz's Avatar
Lightbulb
They Both maybe tied to the same ground wire. I have had other "idiot lights" go off in some of my other vehicles. Since they were under warrenty I took them in and the repair guys always told me there was a loose ground.
Good Luck
Old Sep 27, 2002 | 07:53 AM
fiskr's Avatar
If there is actually an oil pressure problem, then the computer should store the code for it. If you have an Autozone near by, go see them and ask them to use the code reader and see if it shows anything.
Additionally, if your oil pressure is suddenly dropping off, you will notice that the engine sounds very DIFFERENT. Oil starvation will make for very noisy bearings (very unsettling). If it lasts for more than 2-3 seconds. Shut down immediately. You could have some crap in the oil pan getting sucked up into the oil pump intake screen and blocking flow. This will certainly cause oil pressure to drop.
Bottom line is, if the oil pressure is dropping off you will be able to hear it. Don't ignore it.
rf
Old Sep 27, 2002 | 08:29 AM
peterbilt's Avatar
Bob,
Like ROUSHFAN-1 said it seems like an electrical problem. Have you done any modifications like a new radio etc. lately. Someone posted a way to test the panel. Not sure where I saw it, but you turn the ignition on while holding in the trip button. If I find it I will post it. Good luck.
Pete
Old Sep 27, 2002 | 04:54 PM
Silent Bob's Avatar
Does any one know where to find an electical schematic? I might have another project this weekend.
Old Sep 27, 2002 | 04:56 PM
ROUSHFAN-1's Avatar
he's got a 97 i don't think it will work he doesn't have the digi- odometer .....
Old Sep 27, 2002 | 11:50 PM
alaskakristine's Avatar
That happened to me, too, but the radio/time display, which never worked before, came back to life. Turned out to be something wrong with the electric. I would like to tell you what, but I'm at loss for the right words.
Old Sep 28, 2002 | 11:03 AM
FamilyRide's Avatar
Stay away from the back gate!! Aliens have landed and hidden their craft. You may be invading their electric force field! Give them time to rejuvinate their power supply and launch safely.
You think I'm kidding? Oh you just wait and see.....
(Geez, I need to get out and get some fresh air....)
Old Sep 28, 2002 | 07:01 PM
Silent Bob's Avatar
Well Familyride, you may be more right than you know. I haven't seen them personally, but the back gate leads to Robins AFB, GA. Something more to think about...
Old Oct 1, 2002 | 12:28 PM
WLF's Avatar
WLF
Silent Bob,
You are not alone. This seems to me to be happening more on the 97 and 98 trucks.
Read this post http://198.65.157.241/forums/showthr...threadid=90546
good luck...
Old Oct 1, 2002 | 09:46 PM
ROUSHFAN-1's Avatar
yeah sound right...try cleaning any corrosion off the terminal and tightening the crimp connector on the sending unit........
