F150 Dies After starting
As soon as I start my ford it dies. I can restart it and give it gas and it will run. I am getting a check engine light now.
Is this going to be the O2 sensor or is there something else amiss.
Thise first started about 3 months ago, but only when it was raining.
Any help would be wonderful!
Robby LaFarge
99 Ford F-150 Lariat 5.4 BONE STOCK for now. The corvette is taking all the play money...
Robby LaFarge
Find your PCV and follow the hose to the back of your intake.
The is a rubber elbow that connects the PCV hose to the intake.
If this is rotted or has a hole for any reason, the truck will not run right or run at all. I had this problem and have seen other post with this same problem. It appears that this rubber elbow isn't made of very good stuff. Ford sells the whole assembly from PCV to intake for around $27.
