#7 cyl misfire 5.4L part 2 help quick
Ok, I finally got the fuel rail off and got the #7 coil pack and plug out. That is if #7 is 3rd from the front on the drivers side or 2nd from the back, however you want to say it. The coil pack looks fine(how could I tell if it looked bad?) and the plug looked fine. No gunk or garbage. No oil on plug all connections looked dry past the seals. ????
So what now? Can anyone verify that I took out the right one? Also how can I tell the coil pack and plug are working? Can autozone test them? Can I just crank it over while holding the coil pack and plug next to the block or valve cover and see if it sparks; you know like ya did with the lawn mower. LOL!
Please Help! I gotta have this thing back together quick before It gets dark.
Thanks for any info as always!
Chris.
Chris.
Ok here is my luck. I buy an OBD II code reader. I change the coil pack from the #7 cylinder to the #5 cylinder and vice versa. I disconnect the battery to reset the computer. I turn the key on and check for codes but guess what no codes. So I think well good. Maybe something was loose after all and when I put it all back together I tightened it up. No such luck. I start it up and it still runs like ****. No check engine light and no codes but nevertheless runs like ****. So now what just hope the light comes on again?
Any help?
Thanks,
Chris.
Any help?
Thanks,
Chris.
