Question about Mobil 1.
RangerGuy, I don't know about your results or experience with Mobil 1, but I can assure you that it is, in no way shape or form the "fram" of motor oils. Use whatever motor oil that you want, but always remember that opinions are just like a**holes, everybody has one and many of them stink. Mobil 1 is a first class oil that is PROVEN, no ifs ands or buts....
2000 F150 Lariat Supercab, Oxford White/Harvest Gold, 157"WB, 5.4, 4 wheel Disc ABS, 4R70W, single fact. CD premium sound,
remote keyless entry, full leather, full power access., 3.55 LS, SRW, Class 3, and finally the correct 2.20" double-row radiator....
Mobil 1 5w30 oil with Motorcraft FL-820s
K&N Filtercharger
Penda Bedliner
Solo Radar Detector
K&N Filtercharger
Penda Bedliner
Solo Radar Detector
I swear,
we need a section just for oil and oil filters
Im so tired of this dicussion i dont even wanna give my 2 cents!
To each his own.
97 F150 Longbed V8 4.6
K&N air filter
K&N FIPK tech MOD & removed elbow silencer
Tires: Yokohama 265/75/16 Geolander AT+
Hyper white xenon bulbs
Bedliner and raven shell
6 disc cd changer
Oil & filter used
Gasoline used
My Truck
To each his own.
K&N air filter
6 disc cd changer
Oil & filter used
Gasoline used
My Truck
I think you guys are missing the point. Oil being dirty at the change point is good - it means the dirt is not in the engine.
When high detergent (HD) oil first came out, everyone was in a panic because the new oil was much dirtier at change time than the old non HD oil.
There are lots of contaminants that cannot be captured in a filter. Just because it is dirty doesn't mean it is breaking down!
I have no experience with Amsoil, but Mobil 1 is a premium oil. I read somewhere that GM uses it on the Corvette specifically to avoid having to put an oil cooler on the car. This should tell you it is stable under high temperatures.
Ian
99 Expedition EB
5.4l, 4x4, 4.10 LS
WMS Tube, Bassani Cat Back Exhaust, Superchip Flipchip, PIAA Superwhites
Ian
99 Expedition EB
5.4l, 4x4, 4.10 LS
Mobil 1 oil is very good stuff...and no, it does not suck as others have posted. To say Mobil 1 oil is the "FRAM" of oils is irresponsible at best.
2000 F-150 XLT, 4x2, 5.4L Supercab, Superchip, Styleside, Black with silver two-tone, 3.55 rear, class III towing package with super engine cooling/auxiliary transmission cooling HD package, Heavy duty shocks, 4 wheel disk ABS, overhead console, sliding rear window, keyless entry, dark graphite interior, in dash CD, factory leather wrapped steering wheel, FORD bedliner, FORD black tubular cab steps, K&N air filter, mar-hyde rubberized undercoating, Modine climate filtration system, Bugflector II, Mobil 1 oil, build 7/2000
I did not quite say that Mobil 1 was the Fram of of oil. What I said was that since everybody else uses it people think it MUST be good, the same way that since Fram is the best selling oil filter people also asume they are good. I am sure Mobil 1 is not a bad oil. What I am trying to say is that it certainly is not the best. I believe that Amsoil is a far superior synthetic. I work at a Ford dealership and we recently had a guy in for a new engine in his Taurus with 80,000 miles on it. He had used mobil one since the first oil change, changing at 10,000 mile intervals. When the Techs took off the oil pan it was as dirty inside as an engine that was run on conventional oil. This particular taurus had the 3.0 Vulcan V-6 which has a reputation for being bulletproof. The Mechanics did not seem at all surprised that it was run on Mobil 1. They all agree that Mobil 1 is fine for 3,000 mile changes but would not attempt to run it ANY longer than 5,000. On the other hand Amsoil guarantees that if you have any oil related faliure while changing under there recomended one year or 35,000 mile intervals they will pay for the repairs to your engine.
speedy46, I use Valvoline SynPower 5w30, I too have not heard any negatives. I changed my oil last Saturday after 3300 miles. The oil was still clean and during that time I did not need to add any oil. My truck has 72000 miles and that was the first time I had used any synthetic oil. It's to early to tell if there is a gas mileage increase over conventional oils, but I will be monitoring it.
98 5.4L, 4" Rancho Suspension with 33" BFG on 16" Weld Racing Rims, Chrome Brush Guard, Stainless Stell Steps, Alpine Stereo with 4 5X7 MB Quards run by an Alpine approx. 400 watt amp and 4 He2 Rockford's 10" subs run by a 800 watt Rockford amp, and CB and Scanner
As you all know I am Amsoil all the way!
But, it would seem that Mobil 1 is the factory oil of choice for Corvette, Dodge Viper, Porsche and others. I would say that Mobil 1 would be my choice over just about any other brand.
Lastly, it does seem that Mobil 1 has recently changed their formulation and it does not do as well in the wear protection as it used to. I don't know why this is. I had heard that they started to blend some Group III basestocks--along the same lines as castrol syntec, so they could keep the prices low. But I can't confirm this.
Overall. I would say use any synthetic over a conventional oil anyday!!
My Home Page
Lubrication Forums
My Home Page
Lubrication Forums
Always get a kick out of this debate. Will someone please enlighten me as to how you are measuring the actual performance of your motor oil ? And to those of you professional auto mechanics, When is the last time you saw a oil and oil filter related problem on a vehicle that has had regular oil changes ?
Hey Dondo, I've got one for you. I was recently in the service department of the local Ford. Someone had brought in a car because it the engine was really running rough and was having lots of problems. The car had about 35k miles on it.
A little while later the tech came into the service department to tell the service manager that the car still had the original factory oil filter on it...
2001 F150 XLT Supercab Flareside "Sport"
Black
5.4
Smittybilt step bars
puddle lamps
Ford logo brake light hitch cover
<A HREF="http://members.home.net/deep6blue" TARGET=_blank>
</A><A HREF="http://www.empiremotorsports.com/Html's/Hitch%20Covers%20-%20Order%20Page%203.html" TARGET=_blank>
</A>
Black
5.4
puddle lamps
</A>
This is laughable...I know mechanics that have looked into engines that have run Mobil 1 and they are clean enough to eat off of. Dino-oil on the other hand leaves a black sludge on everything.
I'm not doubting Amsoil is a good oil, but to say Mobil 1 leaves a sludge....LOL!!!
The Truck: 1997 Black F-150 Flareside. Regular Cab ORP and Towing Package
The Mods: K&N Filter, Eurolid Hard Tonneau, Profile Windstream Side Deflectors and Lund X-Terminator Bug Deflector.
The Other Truck:
1991 Ford Explorer Sport
The Other Truck:
<font face="Verdana, Arial" size="2">Originally posted by deep6blue:
</font>
</font>
I've run Mobil 1 in my F-150 for 45,000 miles now. I currently have my engine torn down due to a leaking head-gasket and it is absolutely SPOTLESS on the inside. I am impressed with the cleanliness of the top end, including the valves which have very little build up on the stems. Typically dino-oils leave much more of a carbon build up on the intake valves.
I've changed the oil every 5,000 miles and used 5w-30. I'm not gonna use anything else. I have proof in the garage the stuff is a good oil and I can get it at any retailer nationwide.
