installing shorty headers
Old Jun 2, 2001 | 04:23 AM
mickeys97lariat's Avatar
Question installing shorty headers
just ordered a set of shorty headers for my 97 4.6. has anyone already installed a set and can tell me if there are any special tricks to make it easier.
Old Jun 2, 2001 | 04:45 PM
GoDogGo's Avatar
Post
Hi mickeys97lariet,
I believe it depends on the manufacturer and style (equal length, unequal length). I have heard in some cases where the motor had to be jacked up a couple of inches, and other cases where the starter had to be removed. With the JBA's, they slipped right in. Installation wasn't difficult, just time consuming. Hope this helps.
GDG
Stock Package: 2001 SuperCrew XLT, Silver, 5.4L, 4x4, 3.55 LS, Tow Package, 265x70x17, Sliding Rear Window,
Modifications: Tuff Spray-on Liner, JBA Headers Jet Black Coated, Ravin Z55 SI/DO Sideswept Catback, K&N FIPK with fabricated cold-air box and ram-air, SuperChip, ASP Pullies, 1" Thick Sheepskin seat covers (nice "seat-of-the-pants" feel!), Nerf Bars, PIAA Superwhites, 65W (9006) Fog Lights, Dual 14" Perma-Cool Fans w/ stock shroud, Baumann Shift Kit on Stage 4 with Sonnex Bypass Clutch control Valve, Pillar mounted Autometer Ultra-Lite Water and Tranny Temperature Gages, Amsoil front to back, TPS Mod to 0.997
Future mods - Roots Supercharger, modified sterio system
Old Jun 2, 2001 | 09:23 PM
max mitchell's Avatar
Cool
I am also interested in tips/hassles on the 5.4L Bassani equal length monsters; someone that has actually done it. TIA
2000 F-150 XL, RC, LB, 5.4L, 4R70W, 4.10LS,
Class III tow, Payload #3, & Convenience pkgs.,
4-wheel disc/ABS, Chestnut/Parchment 40/60,
Ford bedliner w/Paintsaver & gas/wheel/spare locks,
K&N F.I.P.K. w/Outwears pre-filter, Superchip,
Dynomax ultra-flow welded 3" cat-back w/ 3" Y-pipe,
Hellwig front & rear anti-sway bars, Rancho RS 9000s,
Pirelli Scorpion Zero 275/60/16s, Mobil 1, K&N oil filter.
Old Jun 2, 2001 | 09:38 PM
Svteam's Avatar
Exclamation
Hello Max
I just installed the Bassani equal lenght headers in my 99 Lariat 5.4L
The installation took me 5 hours
If you are installing yourself first start with the passenger side , its alot easier just remember to cut about 1 inch of your upper shock mount and then do the drivers side , I had to lift the motor about 3 inches to get the headers in and to installed the EGR pipe back in was a pain it didn't quite fit after I installed the headers, I had to bent the EGR pipe and let me tell you that's some hard pipe to bent ( the pipe is made of stainless steel )
Good luck with your headers and don't forget an 8mm 12 point open wrench and a 1"1/4 wrench for the EGR pipe.
Old Jun 3, 2001 | 05:08 PM
Cool
Svteam- Thanks for the tips. I was afraid all the extra equal length bends would be a hassle (lift motor 3").
Old Jun 3, 2001 | 11:07 PM
GoDogGo's Avatar
Post
Svteam ... WOW!
5 hour install time is very impressive, even more so considering you had to lift the engine. I must be getting old. The unequal length shorties I installed (JBA's) slipped right in and it took me a lot more than 5 hours!! LOL!!
GDG
Modifications: Tuff Spray-on Liner, JBA Headers Jet Black Coated, Ravin Z55 SI/DO Sideswept Catback, K&N FIPK with fabricated cold-air box and ram-air, SuperChip, ASP Pullies, 1" Thick Sheepskin seat covers (nice "seat-of-the-pants" feel!), Nerf Bars, PIAA Superwhites, 65W (9006) Fog Lights, Dual 14" Perma-Cool Fans w/ stock shroud, Baumann Shift Kit on Stage 4 with Sonnex Bypass Clutch control Valve, Pillar mounted Autometer Ultra-Lite Water and Tranny Temperature Gages, Amsoil front to back, TPS Mod to 0.999, Custom ported TB.
