Odometer diagnostics
Old Aug 9, 2002 | 01:23 PM
01screw's Avatar
My odometer in dianostics mode is showing a dtc code of "5284" I removed the neg. battery cable and cleared it to "none" but about 20 miles or so later, I got the same code of 5284 again. Does anyone know what the code "5284" is? Thanks!!
Old Aug 9, 2002 | 01:39 PM
AjRagno's Avatar
"5284" is nothing to worry about unless you retrieve this code with the engine running. It's a no oil presure code but you won't have oil presure unless the engine is running.
See if there's another code in there.
Old Aug 9, 2002 | 02:29 PM
01screw's Avatar
Thanks AjRagno!!
No other codes.
Old Aug 9, 2002 | 04:01 PM
F150Europe's Avatar
Question Diagnostic Mode
I know there is a sequence to do to get in diagnostic mode.
Can somebody list it here,please.
TIA
Old Aug 9, 2002 | 04:17 PM
01screw's Avatar
F150Europe,
Just start your engine while holding the odo reset button in and don't release it until your odo reads "test". Once it enters test mode then each time you depress the reset button it will go thru different modes.
Old Aug 9, 2002 | 04:19 PM
AjRagno's Avatar
http://www.mustangworld.com/ourpics/fcar/dtcodes.htm
Old Aug 10, 2002 | 07:03 AM
F150Europe's Avatar
Thumbs up
Thanks.
That is cool.
About the bulbs.
I can see I have a 4x4 bulb.(It is not lighted offcourse, 2wd)
What does low range mean?
Also my bulb for windscreen washer fluid is not lighted, is that correct.
Also bulbs for left, right turn, theft are not lighted.
Is that correct too?
Noticed your speed is 2-3 kph off.
Display reads 27, needle says 30.
RPM's 690-710
No error codes, man the first T-Ford ran better than mine right now.
This is really cool, like they say on mustangworld, you should be able to pull all errorcodes from your display.
BTW Lucky I wrote down my day trip mileage (measuring MPG) cause it was reset to 0.
Old Aug 10, 2002 | 09:38 AM
kidtriton's Avatar
https://www.f150online.com/forums/sh...highlight=code
