Home made intake
Old May 29, 2001 | 04:08 PM
jwrape's Avatar
Red face Home made intake
I installed a homecrafted intake from a 3" exhaust pipe bent in a 90 degree angle. the only thing is I think I've lost something.
While I have gained some mid throttle responce I have lost instant throttle responce.
My main question is, will the bend in the 3" exhaust pipe restrict the air flow more than the stock plastic intake? It is bent in such a way that the pipe is about half as deep as it should be non-bent. I think my instant throttle problem is because of the bend.
I am thinking of replacing my new intake with PVC. What does everyone think? Has anyone done this same thing before? I have read the other threads and haven't seen any other folks with the same issue.
Jwrape
Old May 30, 2001 | 01:11 PM
JMC's Avatar
JMC
25 Year Member
Post
jwrape,
How was the pipe bent? It has to be mandrel bent to keep from restricting the air flow. Check out http://www3.sympatico.ca/jmc.chartier/air1.html That is what I did.
Regards
Jean Marc Chartier
SEE us play;
http://www.F150world.com/michapter/
00 F-150 XLT SC Flairside 4x4 4.6 w/5spd 3.55LSD
Warn XD9000i, skid plates, Draw tite class III,
Rancho RSX Reflex shocks, MAC 8.8 Axle Girdle
BFG 285/75 R16 MTs,
Borla Cat Back, Hedman Headers,
Custom air intake system with modified
air box, Ported Throttle body,
Shortened MAF sensor tower,
K&N air filter,
Superchips
Old May 30, 2001 | 01:46 PM
jwrape's Avatar
Post
Who usually has this machine. Not ever muffler store? Right? Anyone particular?
Old May 30, 2001 | 05:01 PM
Neal's Avatar
Cool
HI!... JWRAPE : I used a HEDMAN 3.5 inch 90 degree mandrel bent primary tube. PART # 12006. I then bought a "MEGS" tapered exhuast tip and cut it to match the 3.5 inch diameter 90 degree bend and cut the other end to match up to my TB. I then TIG welded the tip to the bend. I then drilled two holes for my EGR hoses and welded on nipples fro the hoses to slide over. Hope this helps you out.
NEAL " THE H.P FREAK" E-MAIL :nnewman@sympatico.ca
'99' F-150 XLT SPORT, oxford white, reg cab shortbox stepside,5.4, auto, 4.10L.S, captain's chairs, bedliner, GTS carbon fiber headlight covers, ***** CEPECK clear halogen driving lights, GTS slotted tailight covers (painted oxford white), fiberglass smooth wiper cowl (painted OXFORD WHITE), FORD locking lug nuts, tinted windows,true duel exhaust with 2.5 inch mandrel bent pipes and FLOWMASTER 3 chamber mufflers with 3' tailpipes exiting before the rear wheel like the LIGHTNING, HELLWIG rear stabalizer bar, 3 AUTOMETER guage pods, filled with tranny temp, engine temp, and oil preasure AUTOMETER "PHANTOM" guages,custom fabricated air intake trac and huge K/N filter, TPS mod, BELLTECH 2-inch rear drop, custom programed SUPERCHIP "FLIP-CHIP", BAUMANN ENGINEERING shift kit (on stage 5 setting)BYPASS CLUTCH CONTROL VALVE/PREASURE REGULATOR VALVE, ASP POWER PULLEYS, custom tig welded and ported JBA "JET BLACK coated headers, twin DERALE 16 INCH ELECTRIC FANS, PERMA COOL 14"/10" tranny cooler with 10" electric fan, PERMA-COOL external tranny filter, custom ported (STOCK) throttle body, custom digital air intake temp sensor, custom ported TB intake elbow, relocated ATS, FORD RACING 24LB injectors, RUSSELL stainless steel braided tranny lines with fittings.
FUTURE MODS : BBK 75MM THROTTLE BODY, 80MM PRO-M MASS AIR METER, AADI F1 RAM AIR HOOD WITH CUSTOM FABRICATED RAM AIR SET-UP, CAL-TRAC TRACTION BARS, EXTRUDE HONED INTAKE MANIFOLD, SHM CUSTOM FUEL RAILS, 90/10 FRONT CE SHOCKS, 70/30 REAR CE SHOCKS, BELL TECH 2/4 DROP, EXPEDITION CENTER CONSOLE, HARLEY DAVISON F-150 LOWER FRONT VALANCE (painted oxford white) and a KENNE BELL BLOWZILLA SUPERCHARGER.
ESTIMATED H.P TO DATE : 340H.P / 425ft/lbs of torque.
CURRENT PERFORMANCE : 1/4 MILE - 14.52E.T * MPH - 93.73 * 0-60MPH - 5.8 * 1/8 MILE - 9.2 * 60 FT - 2.0
OTHER TOYS : "83" PRO STREET FORD RANGER : 351-w stroked to 408c.i 625H.P (natural), 875H.P with 250H.P "BIG SHOT" N.O.S kit, tubbed (crome moly tubing), 12 point chrome moly roll cage, 4-link with coil overs, MUSTANG II front suspension, c-4 tranny (race prepped), 4000rpm stall converter(8 INCH), 3" chrome moly driveshaft,AUTOMETER guages, 16.50 MICKEY THOMPSON rear tires, 4" M/T front tires, CENTERLINE CON-VO PRO rims, fiberglass hood - bumper - prostock hood scoop, wishbone trac-link, two chrome moly driveshaft loops, 16 gallon JAZ fuel cell,etc
Old May 30, 2001 | 09:26 PM
98SCREAMER's Avatar
From: Houston, by way of every major city in America.
Talking
JC Whitney also sells mandrel bent exhaust tubing,in pre made 180,45,and 90 bends. Worth looking into for fabricating guys ,,,,98
98 F-150 4.6 Litre XLT 4x2 Ext. cab
prarie tan/tan int.
Yep,it has alot of stuff installed on it,I just got sick of lugging that huge sig. around,hehe
Come and see my newest pictures@ www.my-f150.com
Everything is shown there,except for the Superchip,Thanks Mike T!!
FENDER GUITARS ROCK!!!
Now,if it only looked like this in real life
