Lifter Tick?
Old Mar 5, 2001 | 09:37 PM
bambino's Avatar
Post Lifter Tick?
Hey everyone,
So when i start my truck after it has been off for a while, like in excess of 6 hrs, it seems as tho, before the oil reaches the top of the motor, I can hear some ticking going on. See the sig for truck details.
Is this common to everyone? Am i listening too much to the truck? Any input is always welcomed.
Cheers,
Bambino
Bambino Online
Owners Gallery Truck #179
1999 reg cab/short box/ORP - 3.55; 4.6l 5sp; factory snapless tonneau; twin 6" kicker sub tubes; Custom Exhaust; Mobil 1 5w30/Motorcraft FL820-S
Old Mar 6, 2001 | 12:18 AM
BlueStreak's Avatar
Post
Im glad (I guess) to see that Im not the only one that has this problem. Can we go for a third. Need info please.
Thanx
John
98 F150 XL
Blue/Silver
4.6 Triton V8
Ext Cab. Long Box
3.55 NLS
Tow Package
No Mods Yet
Old Mar 6, 2001 | 09:10 AM
JMTruck's Avatar
Post
Sometimes.
My Ride: 1998 F150 4x4 Lariat Supercab Flareside 5.4L in Oxford White/gold, ORP, Tow Package, 3.55 Gears.
Modifications:
Optima Red Top Battery
Split Fire Spark Plugs
K&N FIPK
Gibson Supertruck Exhaust System
Stepshield door sill protectors
Performance Accesories 3" Body Lift
Performance Accesories Lift Lips by Mountain Enterprises
Superlift 3" lift blocks
Gabriel Gas Ryder LT VST Shocks
Daystar Front Anti-sway Bar Polyurethane Bushings
Heckethorn Steering Stabilizer
35x12.5R16.5LT BFG All Terrain KO's
16.5x9.75 American Eagle 589's.
McGard Premium Wheel Locks
Photos at: http://www.communicomgroup.com/jmtruck
Old Mar 6, 2001 | 10:05 AM
Road Rash's Avatar
Post
Could be the PS problem.
Mine sounds like lifters also, dealer diagnosed it as Piston slap.
99EB Expy
Old Mar 6, 2001 | 11:12 AM
DonW's Avatar
Post
Make sure you are using motorcroaft oil filters. Must have the anti drain back valve.
my 2 cents
Don W
97 F150 4X4 XLT, ORP, Tow Package,
CD-Changer, K&N, B&M shift improver,
PIAA fog lights, Weld Rims 17", 265 70LT AT/S, Flowmaster 40 series 3" cat back.
f1504x4.hompeage.com
Old Mar 6, 2001 | 11:48 AM
Hawkeye's Avatar
Post
Sometimes yes, sometimes no.
Does not sound like piston slap. I thought it might be the injectors clicking since they are pumping more fuel than normal owing to the engine being cold. Goes away after a few seconds.
I only use Motorcraft filters and 5W-30 Mobil 1 oil.
'99 Lightning
late July '99 build date engine engine
(supposedly after piston slap fix)
Old Mar 6, 2001 | 01:10 PM
moose-man's Avatar
Angry
I have this same exact problem.
The ticking is worse the colder it is!
A few minutes later its gone, i thought it was the piston slap issue but my engine is a romeo and according to the TSB not one of the infected batches. So ive come to the conclusion that either its some other mechanical part or ford is lying their @#4ing a$$ off which i personally believe is true.
By the way i only use mobil 1 5w30 and Mobil 1 filters which also have the drainback valve.
My rig has 81k on it so no warranty for me lets pray if it is the piston slap how long she can lasT!
97 F150 Longbed V8 4.6
K&N air filter
K&N FIPK tech MOD & removed elbow silencer
Tires: Yokohama 265/75/16 Geolander AT+
Hyper white xenon bulbs
Bedliner and raven shell
6 disc cd changer
Oil & filter used
Gasoline used
My Truck
Old Mar 6, 2001 | 05:01 PM
bambino's Avatar
Post
Some more info:
I have a buddy with a windsor 4.6 and it has slap, my truck definately does not have slap with it's romeo motor. The tick only lasts about 3-5 seconds when the motor is cold and the temps are above freezing. Today - about 10 degrees C, there was no tick, or very little.
I am using a FL820S with mobil 1 5w30. Oil level is perfect...
Thanks, and i'm looking forward all respsonse.
Bambino Online
[This message has been edited by bambino (edited 03-07-2001).]
Old Mar 7, 2001 | 02:46 PM
bambino's Avatar
Post
Just some more info, again...
today it was 10C and there was only about half a second of lifter tick. wondering what sort of climates other people are in when they are hearing the same symptoms.
Bambino Online
Old Mar 7, 2001 | 05:41 PM
Dennis's Avatar
Post
My guess. Valve in the filter isn't up to spec. See if it stops with your next oil/filter change.
My truck can sit for three days and it starts up quiet. No ticking.
Dealer does the servicing. No idea what kind of oil, but the filter is Motorcraft.
Old Mar 7, 2001 | 07:17 PM
Y2K 7700 4x4's Avatar
Cool
If you suspect sticky lifters, try some engine detergent like CD-2. There are at least two CD-2 products -- and one is as thick as STP -- the other, when shaken, sounds like a can of water (that's the one you want).
Years ago -- the product was called something like "Alamite CD-2" -- which was very thin and mostly of a solvent in nature. It worked within seconds (literally -- like 60 or 120) on lifters that were apparently sticking due to being 'gooey'.
The current product doesn't appear to be the same -- but I've seen it work in a few miles of driving on several vehicles in the past half-dozen years or so.
I suspect that Mobil 1 does NOT have a heavy dose of detergent -- inferred by referencing the 4. First Aid Measure portion of the Material Safety Data Sheet (MSDS) which reads: "INGESTION: Not expected to be a problem. However, if greater than 1/2 liter (pint) ingested, seek medical attention..." !!!
So -- if you can ingest up to ONE PINT of Mobil 1 10W-30 before seeking medical attention -- just how much in the way of additives can it contain?!? (Stay close to that toilet, though -- ).
BTW: My friend's 5.3 1999 Z71 rattles like there's no oil in it for the first second or so upon start-up -- so oil-starved lifters is not a Ford-only 'feature'.
[This message has been edited by Y2K 7700 4x4 (edited 03-07-2001).]
Old Mar 7, 2001 | 09:14 PM
rtifactman's Avatar
Post
y2k,
Is that CD-2 stuff available at walmart, auto store, where??? is it just called CD-2?
I may be interested in using it. Is it something you drive around with for a while, or just let idle?
Oh, by the way, not to swell your head, but I joined this board in Febraury, and I have to say that you are the most informative, knowledgable, and helpful person I have seen so far. In the engine catagory and the transmission catagory. Thanks for all the help you have given me and everyone else. I did a search the other night of posts that you have replied to, or posted on, and I found a volumes of inforamtion. It was great.
Thanks again!
James
Old Mar 8, 2001 | 07:56 PM
Krusher's Avatar
Post
Hi new here great info on this site.Regarding lifter noise. U sure its lifters? I had same "noise" And it turned out to be the starter hanging up slightly. Only does it when its cold. Just an idea!
Old Mar 8, 2001 | 09:25 PM
Post
rtifactman:
No swelled head -- but it DID make my day. Thank you.
I saw the CD-2 at Meijer last evening (after I posted it, I was out for a shopping stroll). It is in a bright yellow plastic bottle.
I had used Mobil 1 nearly exclusively for 130,000+ miles in my Excort -- and despite 3k oil changes, the lifters did get a bit sticky -- and one hammered like a champ for minutes upon start-up at times. The CD-2 worked for that engine -- a one-time shot -- and I've seen it work on several others.
With the super-clean operation/burning of today's engines, there is less importance placed on detergents and dispersants than for the 'dirty' leaded-fuel engines of a dozen years ago.
Since it's (CD-2) merely the detergent additive, you just add it and forget it.
My exposure to lubricants is admitedly not with engines, rather it is with transmissions and axles -- where I set up & managed the used-lube field sample program in use at Eaton/Dana for diagnosis & the establishment of an extended-drain interval program for fleets. I (and other team members) worked with the lube supplier which produces the additives and with the lube manufacturer that produces the Roadranger(TM) synthetic lubes -- which are used in Eaton and Dana products with lubricant change intervals of 500,000 miles -- more than 10-times what is allowable using dino-oils. It was Eaton who led the N.A. truck industry into the synthetic gear-lube arena -- and I was lucky to be a part of that development.
While my work was with gear-boxes -- I did pay attention to the engine oil advances - and use synthetics in every engine in my garage.
I enjoy adding technical, anecdotal, and humor-intentioned commentary to this board -- and LOVE my F-150!
Regards.
Old Mar 8, 2001 | 10:09 PM
bambino's Avatar
Post
y2k
I'll chk out some cd-2 this weekend, and report if it does the trick. I'm not sure if this is a new problem, or if i just started to notice it, but i'm led to believe the former. This becuase my truck and I might just share the same heartbeat after all!
Thanks for the replies, I'll keep you posted.
Bambino Online
