AIR FILTER FELL OFF !!
Old May 17, 2001 | 03:48 AM
fordnerdo's Avatar
Red face AIR FILTER FELL OFF !!
today I was washing my truck and I decided to wipe off some dust on my engine compartment when to my shock my air filter on my Air Force One was not connected. I have 10000miles on my 2001 4.6 and I dont know if it was off during my off road expedition. Now what should I worry about, what should I do?? anyone please help
Old May 17, 2001 | 08:19 AM
HarleySupercrew's Avatar
Registered User
Exclamation
That happend to me too, luckily I found it the day after I installed it. I think the pre oiled filter element gets the intake tube and the inside surface of the filter element real slippery and they need to be degreased before instalation. I also put a little racing tape on the intake tube to act as a better gripping surface where you tighten down the filter too. Only takes a strip of tape about 1 inch wide wraped around the intake tube where the filter will be mounted to. Guess every one who instals one of these needs to be double checking for the first few days to make sure they stay on. As far as should you be concerned I don't know. If you have been in dusty conditions I would definately do an oil change now and remove the intake and inspect the inside of the tube for grit and clean it out. That should give you a good idea as to what kind of stuff or amount was going into the intake. Inspect the throttle body to see if it has grit or grime on it and clean it also. Hope this helps, take care.
Photos:
    • 2001 Harley-Davidson Edition Supercrew
      my driver & porsche puller
    • factory supplied options; Harley-Davidson package (includes the 01 lightning suspension package, muffler and aluminum drive shaft), moonroof, 6 disc CD, sliding rear window
    • after market stuff
    • '01 Lightning headlamps, corners and tail lights
    • super chip flip chip
    • airforce 1
    • rockford fosgate amps speakers & sub woofer
    • ford supplied drop-in duraliner w/ Harley Logo
    • class III hidden hitch by Surepull & electric trailer brakes set up
    • tinted front side windows
    • Pro-Fit phone instal kit
    • Ford supplied locking gas cap part # FC-971 XU5Z-9030-FA
    • Ford supplied wheel locks part # YL3Z-IA043-AA
    • ARE LSII bed lid
    • Other Interests Porsches and Porsche Racing;
    • Porsche Car Photos;
    • Race Car: http://www.zing.com/album/?id=4293938833 ;
    • Street Car: http://www.zing.com/album/?id=4293910945
    • Street Car 2: http://www.zing.com/album/?id=4292659923
    Old May 17, 2001 | 08:20 AM
    clancyb's Avatar
    Post
    You know, mine did the same thing. It seems to happen occasionally w/ all of these aftermarket filters. I check mine every time I fill up.
    I'm thinking about drilling a small screw into the filter to help secure it. Does anyone think that's a bad idea?
    2001 Lariat SC 5.4 4x4 LS ORP Class III 17in wheels Captains seats Oxford White
    -Sony ES CDX-M650 Polk EX572a(2 pr.) Dynamats
    -Westin nerf bar, ARE Z series cap, Yakima rack, Bedrug
    -Superchip
    -Air Force 1 FIPK
    -PIAA 520 driving lights behind grill
    -PIAA 1400 fogs in bumper intakes
    Old May 17, 2001 | 09:58 PM
    Wingnut33's Avatar
    Post
    Add me to the list. It has happened to me 3 times. I can usually tell immediately, beacuse the car idles eradically. The RPM's jump up and down. It's pretty noticeable. I got an oil change and forgot about it. So far so good...knock on wood.
    2001 Bright Red Supercrew 4X4, 5.4L V8
    Mods: (shhhh don't tell anyone)
    Superchip
    BFGoodrich TA KO 285/75/16
    Airforce One intake kit
    Exhaust: Hooker AeroChamber Muffler, SI/DO
    SurePull Class III Hitch
    Rhino Liner (Planned)
    Catch-All Floor Mats (Planned)
    Go Buckeyes!
    Go Bluejackets!
    Truck Pull Kills: 4
    Old May 17, 2001 | 11:26 PM
    Registered User
    Post
    That is a good point, I do recall that I could tell that something was up. It did run funny at idle. So you would be able to tell if it came off without lifting the hood.
    <font face="Verdana, Arial" size="2">Originally posted by Wingnut33:
    </font>
