4.55 to 308
Going to go with 308. got 455 gears now. how much will this help in gas miles.
Stock 1988 5 speed 302 fuel injected 4x4 full size... nothing special and looks good still...
it will help out 2 fold but performance will not be what it was at low end. but gas mileage will improve greatly (18-21)
1997 F-150 XLT 4.6 REGULAR CAB, FLARESIDE PACIFIC CLEARCOAT GREEN 5-SPEED. WESTIN NERF BARS, POWER EVERYTHING,BUG SHIELD, EX-TANG SOFT COVER, BED LINER(FORD).
Depends. Do you drive in town or mostly hiway? The 5-speed makes up for the tall gears in all but the highest gear. There was a post here not too long ago where someone was saying increasing your ratio 20% would put 120,000 miles of wear on in 100,000 miles. That would be true if all you ever drove in was top gear. I put 3.73's in the Mustang, which had 3.08's before. I'm still turning around 1800 rpms while cruising, I'm just a gear higher. It's only on the highway where I'm turning higher RPM. And even then I am about even since I never have to hit fourth anymore above 50 mph.
You'll just be going the other way. So where you used to be in 4th doing 30-35 mph, now you'll be in third to keep from lugging the engine.
BTW, you're truck will accelerate ALOT slower.
2000 F150 XLT 4x4 Short Bed. Amazon Green, 5.4L, SuperCab, ORP, Tow Package, Sliding Rear Window, Electronic Shift, Keyless Entry, LT265-70-17 Tires, Clarion Pro Audio, Herculiner Bedliner, Air Silencer Removed.
1994 SVT Mustang Cobra. #1032 of 6009. Black coupe with black leather int., 3.73 rear, Bassani Exhaust, Aluminum D/S, Bridgestone RE-71 255-45-ZR17
My Home Page
My Home Page
