need help!@!@!@!@!!@
how would i find out what kind of gears i have, for example like 355's etc.... I have a 1998 extended cab 4.6 v8 thanks
1998 extended cab
Silver
4.6 v8
Future Mods:
6 1/2 inch fabtech lift
35 inch bfg all terrain tires
3 inch body lift
billet grill
clear corners
euro tail lights
1998 extended cab
Silver
4.6 v8
Future Mods:
3 inch body lift
billet grill
clear corners
euro tail lights
check the little tag bolted onto your rear end with one of the housing bolts. The first few numbers (355, 327) is the ratio you have.
1998 F-150 XLT 4x4 SC 4.6L Auto, Class III hitch, Pioneer Premiere deck, Boston speakers
Look at your axle code on the label inside your driver's side door. Most likely you will see 19 (open,3.55) or H9 (LS,3.55).
2000 F-150 XL, RC, LB, 5.4L, 4R70W, 3.55LS,
Class III tow, Payload #3, & Convenience pkgs.,
4-wheel disc/ABS, Chestnut/Parchment 40/60,
Ford bedliner w/Paintsaver & gas/wheel/spare locks,
K&N F.I.P.K. w/Outwears pre-filter, Superchip,
Dynomax ultra-flow welded 3" cat-back w/ 3" Y-pipe,
Hellwig front & rear anti-sway bars, Rancho RS 9000s,
Mobil 1, K&N oil filter.
