Response from K&N on FIPK performance during hot weather...
Hi All,
I recently wrote K&N to get feedback on the expectations I should have with my FIPK during the summer months. Although I previously thought that the impact of hotter weather would only cause about a 5HP degradation (which would be barely noticible), I have read other opinions on this board that indicate performance is impacted substantially (which obviously had me concerned). Therefore, I figured I would get the opinion of the manufacturer as well...
I have listed the response I got below for your review. Sounds like they make a good point. Any thoughts?
Response from K&N:
You should not see a decrease in performance in the summer months, 100% hot
air is still better than 65% cold air. Even in the summer months our kit
still performs better than the stock air box. If you do not have a super
duty use part# 57-2514-2 (13-14 horspower increase). For the super duty use
part# 57-2525 (11 horsepower increase).
Regards
2000 F-150 XLT Supercab, 5.4L, 4x4, 3.55 gears
Response from K&N:
Regards
- Premium AM/FM Radio with CD
- Polk DX7 Speakers (front), EX7 (rear)
- Smittybuilt sure step bars
- Ford (Duraliner) Bedliner
- Class III Tow Package
- Superchip
- Ravin Z-55 SI/SO Exhaust
- K&N Gen II FIPK
- Eaglite Xenon 100/80w headlight bulbs
- GE 9005 Halogen bulbs (fogs)
I don't know that 100% hot air is better than 65% cold air, I think it should be the other way around.If that is the case then why did my 92 Thunderbird Super Coupe have a intercooler? To cool the incoming air to make more horsepower.I will not run one of those filter paks I don't care what they try to tell you,you are sucking hot air from the engine compartment.
Dennis
Dennis
K&N e-mailed me on this as well. They said this: The increased flow "far" exceeds the warmer air degradation & If it needed a heat shield, we would add one, like we do on other models (These are K&N's opinions).
2000 F-150 XL, RC, LB, 5.4L, 4R70W, 3.55LS,
Class III tow, Payload #3, & Convenience pkgs.,
4-wheel disc/ABS, Chestnut/Parchment 40/60,
Ford bedliner w/Paintsaver & gas/wheel/spare locks,
K&N F.I.P.K. w/Outwears pre-filter, Superchip,
Dynomax ultra-flow welded 3" cat-back w/ 3" Y-pipe,
Hellwig front & rear anti-sway bars, Rancho RS 9000s,
Mobil 1, K&N oil filter.
