Weird truck problems
Anybody ever find out what is wrong with the rough idle problem?
I reset my computer yesterday and the rough idle problem I had months ago came back. This morning the truck actually stalled. And coming home from work it almost stalled twice.
Also has anyone ever heard of this: Most of the time when I open and close a door, the 'door ajar' light stays on anywhere from 1 to 5 minutes before it goes off.
My guess is both of the problems are computer related.
black 97' x-cab 4x4, 5 speed 4.6, black westin nerf bars, pilot ground searchers, borla SS split rear exhaust, K&N genII, bosch +4 plugs, flexalite electric fan, v-tech oval side window covers, IAS shocks
premier 720, pioneer 6cd changer, 12 premier sub, premier componets, 2 soso amps
This truck is for sale.
Order my 2001 in silver, due date is 6-8 weeks from today, 2/10
my soundomain page: http://members.cardomain.com/dontblameme
Can't help you with the idle question, but the door ajar one is pretty simple. The sensor is located in the door latches and has gotten slightly dirty. Use a little WD-40 with the little tube to squirt it right into the latch mechanism inside the door latches. Your door ajar indicator light problem will disappear.
Good luck!
1997 F150 XLT, Flareside , Moonlight Blue, 4x2, SC, Auto, 4.6L, 3:08's, Cargo Cover by Century, Penda bed liner, Blue Oval reciever hitch plug, Driver Design bug deflector, Monroe Reflex Shocks, 235/70/16 Firestone Wilderness AT's, sliding rear window, captain's chairs, Valvoline Durablend Oil, Purolator Pure One Oil Filter, 280 lbs. of traction sand (ahh, winter in the great white north!
), and 119,000 miles and counting!
[This message has been edited by gopher (edited 04-09-2001).]
Good luck!
), and 119,000 miles and counting![This message has been edited by gopher (edited 04-09-2001).]
The WD40 will work...........!
97 F150 Longbed V8 4.6
K&N air filter
K&N FIPK tech MOD & removed elbow silencer
Tires: Yokohama 265/75/16 Geolander AT+
Hyper white xenon bulbs
Bedliner and raven shell
6 disc cd changer
Oil & filter used
Gasoline used
My Truck
K&N air filter
6 disc cd changer
Oil & filter used
Gasoline used
My Truck
