TPS mod (mine was already at 1.286???)
ok we tried it out on my cousins screw and his was .943 we brought it up to .999
then we went to do my truck and it was already at 1.286???
i have the superchip in so is this what is making it so high
or is that just what it was set at the factory?
my truck has always had better throttle response than my friends 5.4 but i but i just figured mine was built on a good day or his on a bad day lol
wassabi----
i almost bet Neal will be here so im gonna ask this to.... on ur custom FIPK do you have a heatshield? since it is sucking in hot air from the motor will it hurt the motor any? how did u mount all the sensors and the MAF?
1999 F-150 Supercab Styleside Lariat 5.4L V8 3.55LS gears
Tan Leather Seats Front/Back
Captain Chairs in front
Remote Entry
Signal Mirrors
Basically Loaded
Navigator Front End
Factory 2tone Red on top of Gold
Metallic Flake Ghost Flames in the gold
18inch "Lincoln" Wheels w/ Custom Lincoln Center Stickers
Lowered 3/4
Rhino Bedliner
APC Euro "Atezza" Tail Lights
Stock CD player
Rockford Fosgate Punch 250a Amplifier
2 RF Punch 8inch Subwoofers (Need Replaced, Recently Blew)
2 Kenwood Midranges (in the front doors)
Superchip
K&N "Drop In" Filter
Flowmasters
Some Quick Photos (needs updated)
www.geocities.com/thepyromaniackid
Soon to be sponsored/cash-advance deal that will include following parts: (if it goes through)
Vortech Supercharger V1 S-Trim 6psi
75mm Throttle Body
24lb Injectors
Pro-M Mass Air Flow Sensor
H.D. Automatic Transmission Oil Cooler Kit
Shift Kit
True Duals
Custom Burned Chip
White Face Gauges
Autometer A Pillar Dual Gauge Pod
Boost/Vacuum Gauge
Oil Pressure Gauge
Wanted Future Mods:
Airbag Suspension
Dual Electric Fans
Heads
Headers
8psi belt
Stock 1/4 Mile (bad track, temperatures, elevation)
....16.87
....16.91
1/4 Mile Goal: (at our track)
....14.9
(Stock 87-93 Mustang GT's run a slow 15.5 at our track)
jomommaishere@excite.com
wassabi----
Remote Entry
Signal Mirrors
Basically Loaded
Navigator Front End
Lowered 3/4
Rhino Bedliner
Stock CD player
Superchip
Flowmasters
75mm Throttle Body
24lb Injectors
Shift Kit
True Duals
Custom Burned Chip
White Face Gauges
Boost/Vacuum Gauge
Oil Pressure Gauge
Wanted Future Mods:
Airbag Suspension
Dual Electric Fans
Heads
Headers
8psi belt
....16.87
....16.91
....14.9
HI!... PYRO : If your TPS was set at that voltage from the factory and you have NO idle problems, leave it alone. The SUPERCHIP does not effect the TPS at all.
My custm fabricated FIPK, used to have a aluminum heat sheild under it but I have since removed it. I'm now going with a PERMA-COOL heat sleeve instead. My ATS has been relocated to the outside of my hood. All other sensors are in their stock location. Hot underhood air will not HURT your engine. It will cost you some H.P though. That is only when your truck is sitting still or going very, very slowly. At normal driving speeds a kind of vacuum is created under your truck. This vacuum sucks the hot underhood air out and replaces it with cool outside air. I've already proven this with 2 digital temp guages that I have installed in the MAF and outside the truck. The underhood air temp is usually only about 5 degree's hotter that the outside temp when running at normal speeds. Hope this helps you out.
NEAL " THE H.P FREAK" E-MAIL :nnewman@sympatico.ca
'99' F-150 XLT SPORT, oxford white, reg cab shortbox stepside,5.4, auto, 4.10L.S, captain's chairs, bedliner, GTS carbon fiber headlight covers, ***** CEPECK clear halogen driving lights, GTS slotted tailight covers (painted oxford white), fiberglass smooth wiper cowl (painted OXFORD WHITE), FORD locking lug nuts, tinted windows,true duel exhaust with 2.5 inch mandrel bent pipes and FLOWMASTER 3 chamber mufflers with 3' tailpipes exiting before the rear wheel like the LIGHTNING, HELLWIG rear stabalizer bar, 3 AUTOMETER guage pods, filled with tranny temp, engine temp, and oil preasure AUTOMETER "PHANTOM" guages,custom fabricated air intake trac and huge K/N filter, TPS mod, BELLTECH 2-inch rear drop, custom programed SUPERCHIP "FLIP-CHIP", BAUMANN ENGINEERING shift kit (on stage 5 setting)BYPASS CLUTCH CONTROL VALVE/PREASURE REGULATOR VALVE, ASP POWER PULLEYS, custom tig welded and ported JBA "JET BLACK coated headers, twin DERALE 16 INCH ELECTRIC FANS, PERMA COOL 14"/10" tranny cooler with 10" electric fan, custom ported (STOCK) throttle body, custom digital air intake temp sensor, custom ported TB intake elbow, relocated ATS, FORD RACING 24LB injectors, RUSSELL stainless steel braided tranny lines with fittings.
FUTURE MODS : BBK 75MM THROTTLE BODY, 80MM PRO-M MASS AIR METER, AADI F1 RAM AIR HOOD WITH CUSTOM FABRICATED RAM AIR SET-UP, CAL-TRAC TRACTION BARS, EXTRUDE HONED INTAKE MANIFOLD, SHM CUSTOM FUEL RAILS, 90/10 FRONT CE SHOCKS, 70/30 REAR CE SHOCKS, BELL TECH 2/4 DROP, EXPEDITION CENTER CONSOLE, HARLEY DAVISON F-150 LOWER FRONT VALANCE (painted oxford white) and a KENNE BELL BLOWZILLA SUPERCHARGER.
ESTIMATED H.P TO DATE : 340H.P / 425ft/lbs of torque.
CURRENT PERFORMANCE : 1/4 MILE - 14.53E.T * MPH - 93.00 * 0-60MPH - 5.8 * 1/8 MILE - 9.2 * 60 FT - 2.0
OTHER TOYS : "83" PRO STREET FORD RANGER : 351-w stroked to 408c.i 625H.P (natural), 875H.P with 250H.P "BIG SHOT" N.O.S kit, tubbed (crome moly tubing), 12 point chrome moly roll cage, 4-link with coil overs, MUSTANG II front suspension, c-4 tranny (race prepped), 4000rpm stall converter(8 INCH), 3" chrome moly driveshaft,AUTOMETER guages, 16.50 MICKEY THOMPSON rear tires, 4" M/T front tires, CENTERLINE CON-VO PRO rims, fiberglass hood - bumper - prostock hood scoop, wishbone trac-link, two chrome moly driveshaft loops, 16 gallon JAZ fuel cell,etc
