Engine oil changing habits?
With all this new synthetic oils around, is anyone out there running their trucks 10k, 20k, 25k miles as this oil maufacturers suggests?
My Ride: 1998 F150 4x4 Lariat Supercab Flareside 5.4L in Oxford White/gold, ORP, Tow Package, 3.55 Gears.
Modifications:
Optima Red Top Battery
Split Fire Spark Plugs
K&N FIPK
Gibson Supertruck Exhaust System
Stepshield door sill protectors
Performance Accesories 3" Body Lift
Performance Accesories Lift Lips by Mountain Enterprises
Superlift 3" lift blocks
Gabriel Gas Ryder LT VST Shocks
Daystar Front Anti-sway Bar Polyurethane Bushings
Heckethorn Steering Stabilizer
35x12.5R16.5LT BFG All Terrain KO's
16.5x9.75 American Eagle 589's.
McGard Premium Wheel Locks
Photos at: http://www.communicomgroup.com/jmtruck
Modifications:
K&N FIPK
Well, I dont' put 25,000K in 1 year on my truck.
But the oil in there currently has been in there since las Jan 00. So I have had it in there over 1 year. About 10,000 miles.
I need to get off of my butt and do an analysis to see how it looks.
But yes there are folks out there running the oil as it was designed.
My comment is if you are scepticle when you put the oil in, buy yourself about 5 oil analysis kits. Take an analysis every 5,000 miles. you will then know for sure that the oil is even better than advertised.
BTW I am running the 0w30 Series 2000. It says on the bottle can be used for 1 year or 35,000 miles.
My Home Page
Lubrication Forums
My Home Page
Lubrication Forums
I plan to stick to conventional 5W-20 that FORD reccomends. Any engine will last 200K plus anyway.
However, I did look at a bottle of synthetic at WalMart last night. I wish for the life of me I could remember which brand (castrol,penzoil?), but it was a full synthetic and it suggested 3000 mile change!
Even a bigger ripoff to you synthetic users.
I am here to tell you Amsoil is great stuff! No, I have no vested interest either, yes I am a preferred dealer but I only have the membership so I can get better pricing, I dont sell it to anyone. Now that my truck is broke in I am installing AMsoil this weekend. From past experience 35k miles is honestly nothing for this oil. My 94 Ranger with the dual filter kit ran 75k on the same oil, anylsis done every 5k miles. It was in excellent shape even with 75k miles on the oil. I just wanted to switch from 5-30 to 0-30 in it. Good friend of mine uses Amsoil in all his cars, his Cadilac has about 63k on its oil, testing shows it is still in great shape. His Maxima that his teenage son know drives (and drives the hell out of) now has I believe around 110k miles same oil. I am here to tell you, if you run that dual filter system this stuff will last!! Git ya some!!
Jeff Randol
2000 Ford F150
Ext. Cab 4x4 Lariat
5.4 Auto, Off Road Package, Fully Loaded
& lovin it!!
MODS: KN Air Filter
Glasspack exhaust
Upcoming: AMSOIL Dual Oil filter system, FIPK, Fiberglass Topper, Spray-In Bedliner, Wood Dash Kit
Jeff Randol
2000 Ford F150
Ext. Cab 4x4 Lariat
& lovin it!!
MODS: KN Air Filter
Glasspack exhaust
Pretty impressive oil stories, Jeff!
But I like getting under my truck every few months and getting dirty. Impresses the divorcee across the street!
* 2000 F-150 XLT Black FS; 5.4L; 4x4 ORP
* Da Flip Chip! * 3.55 Limited Slip * Stepups
* Sliding Rear Window * 6-Way Power Seat
* Remote Keyless Entry
* Lund Trident Bug Shield * Custom Exhaust
* Fumoto Oil Drain Plug Valve (a must for do-it-yourselfers!)
* Wise Bedrug
So many mods, so little cash! On the up side, no wife to create a filibuster.
* Wise Bedrug
i dont drive much so i change my oil every 2500 mile or 3 months. if u dont drive much usually means u dont drive far. so what happens is the motor doesnt get to it running temp and moisture get traped in side and rust form in the motor. thats why i change every 2500 miles or every 3 months which ever comes first.
msparks- Is Series 2000 the brand?
newtruckforray- Based on the truck manual they recommend 3000 miles oil change for severe duty vehicles and 5000 miles for normal or light duty vehicles.
I am still changing it every 3000 miles. I am not sure if I will change that habit but I am open to changes and new ideas.
Modifications:
K&N FIPK
Modifications:
K&N FIPK
<font face="Verdana, Arial" size="2">Originally posted by JMTruck:
</font>
</font>
The Brand is Amsoil, the Series 2000 is the newest oil, with the best additive package and base stock. The Series 2000 is recommended for 35,000 miles or 1 year whichever comes first.
My Home Page
Lubrication Forums
I have watched the threads on the site about oil changes and synthetics a lot so I wrote to Ford to ask them their recommendation-they responded that they recommend 3000/5000 mile changes as noted above regardless of synthetic or mineral oil. I personnally use Mobil 1 because I think it will keep the valves longer and change the oil every 5000. Yea, I think it would probably last longer but I put 12,000 miles a year on the truck and it costs me an extra $30 a year to change the oil, hell I figure it is worth it.
</font>
</font>
yes--have '97 f-150 4.6 4x2 with 116,000 miles on it. i bot it used 2 yrs. ago. don't know what oil the first two owners used but i doubt if it was a synthetic. i,ve used mobil 1, redline, and/or royal purple for many years. usually run 10,000 miles before changing. i also use an engine flush each time on my high mileage vehicles.
i got a old olds cutlass i havent changed the oil in it for 7 years now about 80 k on the oil still runs great i only use it to go to work and home round trip is about 10 miles i might change this weekend just to see what the inside of the oil filter looks like lol plugged probley
Guys - way back when - I purchased a 1969 Ford Galaxie 500 with V-8 and auto.
I drove it all over for about 7 years and I never changed the oil or oil filter in all of that time.
When I traded it in on a new one it was still running fine.
All this on conventional oil. If conventional oil does this why do you need synthetics?
I use Motorcraft oil in my 1996 F-150 and motorcraft filter. Still going strong with no problems.
As P. T. Barnum said "there's one born every minute".
My opinion.
My opinion.
Min. Sugg. Retail, ( Sign up for a dealer and the cost is cheaper, click on the PureAmsoil @ the bottom and sign up )
TSO-QT - SERIES 2000 - SAE 0W-30 Synthetic Motor Oil - (1) quart bottlle $8.10
TSO-01 - SERIES 2000 - SAE 0W-30 Synthetic Motor Oil - (12) quart bottles $96.00
TSO-1G - SERIES 2000 - SAE 0W-30 Synthetic Motor Oil - (1) gallon bottle $30.55
TSO-04 - SERIES 2000 - SAE 0W-30 Synthetic Motor Oil - (4) gallon bottles $120.00
http://www.amsoil.com/products/tso.html
Hey is what it can do.
Ruger's F-150
E-MAIL ME:
pureamsoil@bigfoot.com
MY HOME PAGE:
PureAmsoil
[This message has been edited by ruger-dfw (edited 03-31-2001).]
Ruger's F-150
E-MAIL ME:
MY HOME PAGE:
PureAmsoil
