Chip Install and a UPS rant
Old Mar 16, 2001 | 03:49 PM
Caelistis2's Avatar
Lightbulb Chip Install and a UPS rant
<rant>
So here I am, somewhat peeved that my local UPS driver is such an idiot that he clearly disregards the agreement I made for them to drop off all packages at the front office.
What is being delivered you ask? Why, my Superchip of course.
So they say "We'll deliver it Monday". Yanno, if I wanted it on MONDAY I would not have forked the cash over for overnight delivery.
So, I get to go at 9pm tonight and pick up my packages from the delivery center.
</rant>
<question>
How difficult is it to install the chip and what all must be done? I assume these directions may/may not be included with the package so I thought I'd ask.
</question>
Christopher Caelistis
Old Mar 16, 2001 | 03:52 PM
Stayblown's Avatar
Post
Caelistis 2
There is an excellent instruction guide found in technical articles.
Old Mar 16, 2001 | 04:31 PM
ragarm's Avatar
Thumbs up
Hey Caelistis2!
I am by no means a gearhead, greasemonkey, bolt bugger...nothin' like that. I change my oil and that's about as far as it goes.
I installed my Superchip (Flip Chip)in just over an hour. And with the 4x4 off road package, I had to take out by battery and its bracket which added up to 15-20 minutes to the job.
Bottom line, if I could do it, I'm thinking anybody can!
Oh, and it smokes!
* 2000 F-150 XLT Black FS; 5.4L; 4x4 ORP
* Da Flip Chip! * 3.55 Limited Slip * Stepups
* Sliding Rear Window * 6-Way Power Seat
* Remote Keyless Entry
* Lund Trident Bug Shield * Custom Exhaust
* Fumoto Oil Drain Plug Valve (a must for do-it-yourselfers!)
* Wise Bedrug
So many mods, so little cash! On the up side, no wife to create a filibuster.
Old Mar 16, 2001 | 05:29 PM
FamilyRide's Avatar
Thumbs up
If you got it from Mike Troyer the instructions are great. Read them first if you're not sure how it's done. It'll help to have a good idea first.
It's really easy. 2 things to watch for, clean the contacts good, but not so much you're removing metal. Just take your time and look closely; you can see the coating that need to come off. Next, be sure when you put the computer back in, the bracket doesn't rest against the Superchip. It could push the chip far enough off to cause no-start. You should only need to bend the tab on the bracket back a little. You'll know what I mean when you see it. I pulled my bracket out and flattened it smooth, but that was **** and over-board.
Good luck.
2000 EDDIE BAUER EXPEDITION 4x2
-->Come share my Addiction<--
[This message has been edited by FamilyRide (edited 03-17-2001).]
Old Mar 16, 2001 | 07:36 PM
JMC's Avatar
JMC
25 Year Member
Post
Caelistis2,
Check out http://www.svtlightnings.com/svt/chip/chip.htm
Regards
Jean Marc Chartier
00 F-150 XLT SC Flairside 4x4 4.6 w/5spd 3.55LSD
Warn XD9000i, skid plates, Draw tite class III,
Rancho RSX Reflex shocks, MAC 8.8 Axle Girdle
BFG 285/75 R16 MTs,
Borla Cat Back, Headman Headers,
Custom air intake system with modified
air box, Ported Throttle body,
Shortened MAF sensor tower,
K&N air filter,
Superchips
Old Mar 16, 2001 | 09:03 PM
cyclone's Avatar
Post
Caelistis2,
I agree with FamilyRide -- be sure to take your time and clean the contacts extremely well. Mike T's instructions do an excellent job explaining this. I actually used a four step process (1) using a small flat head screwdriver, gently scrape the coating off of the contacts (2) use a pencil eraser to go over the contacts and get any additional small particles (3) using rubbing alcohol on a Q-tip, clean the contacts (4) check to see if the contacts are "completely" clean by scraping with the screwdriver again under a bright light. If there is any coating left (white shavings) repeat the process again. Continue to do this until there is no more shavings. Finish the process with a final pass with the Q-tip (in alcohol). Taking your time here will ensure you only have to do this once.
My final recommendation is to remove the battery and tray. I tried to do it initially without removing these and had a fair amount of trouble (and frustration) attempting to reach the nut. Removing the battery and tray will add about 15 minutes to the process, however, it will save a few degrees of blood pressure
The entire process took me about 1 hour.
Good luck!
Old Mar 16, 2001 | 10:40 PM
FedExPilot's Avatar
Post
Caelistis2,
It sounds as though you were expecting a Saturday delivery (??). If so, UPS doesn't make Saturday/ Sunday deliveries. Don't blame your courier - - they're great guys ... especially, given they are working for UPS. BTW, FedEx (Express) does deliver to certain areas on Sat/ Sun (large metropolitan areas) at a considerable surcharge. It's the same old story - - you get what you pay for; and ... if you want it on time ... send it FedEx .... just my (bias) $.02.
<A HREF="http://albums.photopoint.com/j/View?u=1023393&a=8790857&p=28542295&Sequence=1" TARGET=_blank> </A> <A HREF="http://albums.photopoint.com/j/View?u=1023393&a=8790857&p=28542675&Sequence=2" TARGET=_blank> </A>
2001 F-150 Super Crew Lariat 4x4
5.4 engine; Chestnut w/ gold trim; Captain's Chairs; Ford/ Duraliner bed insert; Access Roll-up bed cover; Six disc CD changer in '98/'99 Expy center console; Fosgate FNP1614 component speakers (front); Pioneer TS-A6855 speakers (rear); 8 inch MTX sub in custom built, center console, sealed enclosure; Zapco AG150 amplifier; DRL daytime running lights; Moon roof; Bed extender; Class 3 trailer hitch
[This message has been edited by FedExPilot (edited 03-17-2001).]
Old Mar 17, 2001 | 08:35 AM
JimWright's Avatar
Post
UPS is the great Satan, incompetent and evil to boot. I once had a package delivered COD, for which I paid by money order. They then lost it, and then came after me for the money with a collection agency despite a clear record of having already received it. I was able to get the money order replaced at my own time & expense, but if the lost one ever showed up and was cashed I'd owe money for the duplicate to the post office and would undoubtedly have to sue to recover it... I used to think it was a great company, but I would never voluntarily do business with them after that... if I'd paid cash we surely would have been in court...
-- Jim
Old Mar 17, 2001 | 07:06 PM
signmaster's Avatar
Question
<font face="Verdana, Arial" size="2">Originally posted by FedExPilot:
Caelistis2,
It sounds as though you were expecting a Saturday delivery (??). If so, UPS doesn't make Saturday/ Sunday deliveries. .... just my (bias) $.02.
</font>
I hate to fill you in on this, but last Saturday my UPS man was at the door.
Old Mar 17, 2001 | 07:12 PM
FamilyRide's Avatar
Arrow
How'd this get off onto UPS? He posted on Friday when the package didn't get delivered where he expected it too.
So, on to that install, how did/is it going?
--&gt;Come share my Addiction&lt;--
Old Mar 17, 2001 | 08:31 PM
FedExPilot's Avatar
Post
Signmaster;
You're right. UPS now delivers on Saturdays ... must be trying to keep up with us (FedEx). I guess they'll try to match our Sunday service next.
Familyride:
My apologies for interrupting your train of thought ..... LOL
5.4 engine; Chestnut w/ gold trim; Captain's Chairs; Ford/ Duraliner bed insert; Access Roll-up bed cover; Six disc CD changer in '98/'99 Expedition center console; Fosgate FNP1614 component speakers (front); Pioneer TS-A6855 speakers (rear); 8 inch MTX subwoofer in custom built, center console, sealed enclosure; Zapco AG150 amplifier; DRL daytime running lights; Moon roof; Bed extender; Class 3 trailer hitch
Old Mar 17, 2001 | 10:23 PM
Caka's Avatar
Post
Hey guys, I have installed many chips and it is easy. I'd love to help but I'm an idoit UPS driver. UPS has been delivering on Saturdays for a long long time. I dont know the just of the situations that you might have had with UPS, but 90% of the time it a communication problem between customer, driver and UPS management. As far as FedEx goes, please. UPS delivers more volume than any other service provider in the world. AS far as Sunday goes, I hope we never offer that service. The most positive aspect of UPS is the fact that we have the HIGHEST paid employe's in the industry. UPS drivers starting pay is the current FedEx TOP pay. There IS a reason for that. I hope your next UPS experiance is a plesant one. Peace!
99 White
JDM chip
JDM 90mm MAF
JDM 5' drive shaft
JL loop
JL Air kit
BaBolt single bore TB
Full Bassani
13.13@104.55
www.carm.org
tcaka@austin.rr.com
Old Mar 17, 2001 | 10:39 PM
BlownHarleyFord's Avatar
Question
And Hey!!!
Why is it that Chicks always have a "thing" for those damn UPS drivers? Everytime they come into the shop, the secretaries find an excuse to come out and meet him. DAMMIT!!!!
Disgruntled Mike
Stay Out Of My Taildust
2000 Black Harley Davidson F-150
5.4 Liter v-8
K&N Air filter
20" Polished Aluminum Wheels
275/45/20 Goodyear GSII's
Billet Front Grille
Front Valence W/ driving lights and Billet Insert
3.55 Rear End
Leather Interior
Heated Seats
Hidden Hitch
Orange Pinstriping
Front and Rear Light Blackouts
Lowered 1" Front & Rear
Block heater
Old Mar 17, 2001 | 10:55 PM
King James's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by BlownHarleyFord:
</font>
LMAO
1997 XLT Teal 4.6L Flareside 4x4 ORP. Automatic, Reg. cab, 3.55LS, tinted windows, bug deflector, Dual exhaust, K&N Generation 2 air filter, BullDog keyless entry/remote start(installed myself), Modern 16" wheels, bedliner, Covercraft tonneau cover, White faced gauges, electronic shift on the fly, Clarion ADX5655z Double Din Cassette & CD, 4 Pioneer TS-A6865 speakers and superchip. Going to add headers.
Old Mar 18, 2001 | 05:23 PM
Caelistis's Avatar
Post
All right. The chip install went very well, all things considered (that being extreme amounts of rain and wind).
The only concern I have is about the white goop that covered the contacts. Mine was very.....fluid, for lack of a better word. It came off very easily with a warm, damp cotton towel. The contacts were beautifully clean and silver. Ran a finger across and found nada but solid metal.
Popped the chip in and she started just fine after putting the ECM, battery tray and battery back in.
The GT-150: What happens when you give a GT-40 and GT-90 freak the keys to a truck.
