question for steve41
Old Mar 20, 2001 | 10:11 PM
King James's Avatar
Question question for steve41
Did you put your radio in yourself? Did you just have am/fm cassette before you changed it? What all did you have to trim before it would fit? I got mine partly in but it is being pushed down in the back so the bottom part of the front sticks out.
1997 XLT Teal 4.6L Flareside 4x4 ORP. Automatic, Reg. cab, 3.55LS, tinted windows, bug deflector, Dual exhaust, K&N Generation 2 air filter, BullDog keyless entry/remote start(installed myself), Modern 16" wheels, bedliner, Covercraft tonneau cover, White faced gauges, electronic shift on the fly, Clarion ADX5655z Double Din Cassette & CD, 4 Pioneer TS-A6865 speakers and superchip. Going to add headers.
Old Mar 21, 2001 | 12:34 AM
steve41's Avatar
Post
Yes, I installed it myself. My truck came with the AM/FM single CD stock. The front of the factory unit is double din but slopes down in the center on back to about single din. There is a chunk of plastic coming down from the inside of the dash that serves as a hanger for the rear of the stock unit. You have to cut that away so it will clear the FH-P4400, which is double din the entire depth. What holds the unit in are two l-brackets from a universal install kit. I screwed into the black plastic structural part of the dash to hold it in. It's been 5 months and it has not budged. You may also want to trim about 1/2" around the bezel stereo opening to make the head unit more flush with the dash. You may also want to shave down the piece of black plastic above the temperature control (where the bottom of the head unit sits) to make the unit sit lower. I used my handy Dremel tool with an assortment of cutting/grinding wheels to make it just right. It took me two nights to do it. Not a quick deal but I liked the outcome. Good luck
2001 SuperCrew XLT White w/gray interior, pwr seat, console, Bed Extender,Autolight, Class III Hitch, Duraliner,
4x2,5.4,3.55,built 6/00
New Transmission 10/00
Pioneer FH-P4400 HU
Pioneer CDX-P1250 12-Disc CD Changer In Console
Pioneer TS-A6895 Front
Pioneer TS-A6865 Rear
Pioneer GM-X542 Amp bridged at 150W RMS
Bazooka RS-604 under rear seat<a href=http://albums.photopoint.com/j/AlbumIndex?u=1592063&a=12123932>See my photos of steve's 2001 SCrew at PhotoPoint</a>
