Oil Filter Relocation
Old 03-16-2001, 08:33 AM
Rickesh's Avatar
Talking Oil Filter Relocation
Installed TD Performance Kit. (30 in. Lines)
Easy Job!
Mounted Filter Bracket To The Base Of
The Radiator Support.
(Screws Provided Clear Radiator)
Oil Change Now A Sit-Down Job!
Available At: SummitRacing.com
1-800-230-3030
Changes Filter To:
FRAM PH7A Or Equivalent
P.S. If You Find The Ford Engineer Who
Put The Oil Filter Where It Was....
PLEASE KICK HIM/HER
[This message has been edited by Rickesh (edited 03-17-2001).]
Old 03-16-2001, 10:00 AM
Hunter Jeff's Avatar
Thumbs up
Can you please post some more info on this? Where did you get the kit? Post a link if you have one. Thanks for any help you can give me, I really want to do this.
2001 xlt,Super Cab 4.6,4x4,5sp,3.55 rear, Bright Red, 17inch, 10 spoke factory wheels
Old 03-16-2001, 10:13 AM
XTRUKY's Avatar
Post
After the relocation, did you use the same FL-820-S filter, or did you go bigger, etc?
2001 Lariat SCrew Oxford White / House of Kolor Sunset Orange Pearl 2Tone.
TruckMaster Designs FD630-S AirDam,AirAid,Gibson9504/Split Rear Exhaust,Fac Moon Roof,3:55LS,6CD,Gen III/Beige,Steps,Slider,Tow,Capt's,Bed Extd, Bell Tech 2" Shackles
Check out my Photo's at
http://photos.yahoo.com/bc/xtruky
Old 03-16-2001, 08:44 PM
signmaster's Avatar
Exclamation
I'm almost certain the Summit sells the TD kits.
Many relocation kits will use a different filter. They will specify which filters can be used with the kit.
I agree on kicking whoever designed this. What's even worse is that they used the remote from the factory and then dropped it. Anybody who changes there own oil would have probably paid for the option, even if it was more than buying a kit. Kick that guy several times for me.
Quick Reply: Oil Filter Relocation
