4.6 L Oil Leak
Old Mar 15, 2001 | 12:21 AM
willards1's Avatar
Question 4.6 L Oil Leak
Hey guys....just a quick couple of questions:
I have the dreaded 4.6L R/side oil leak. When I take it into the dealer should I remove my Air Raid and put the stock air assembly back on?
Also, What was the fix for the above mentioned leak.....head gasket, engine? I just want to know what to expect when I get there.
Thanks in advance....this site has been great:~)
2000 F150 SuperCab 4X4 ORP; 4.6L Engine; 5 Speed Manual Transmission; Hellwig Anti-Sway Bar; Westin Step Bar; Air Raid FIPK
Old Mar 15, 2001 | 12:30 AM
ksdoxey's Avatar
Post
I think its pretty standard for them to check the head and block for defects and then change the head gasket...if this doesnt work, most are getting new/fqr engines...
I had my gasket changed and it seems to have done the trick for now....only time will tell.
Best of luck
1999 F-150 XLT SuperCab - Sport Package, 5.4L, 3:55 Ratio, 2WD, Gold/Tan, (MFG date 5/99)(Repaired leaker!!)
