accelerator sticking - almost blew up my engine
Old Mar 12, 2001 | 10:59 AM
barngoddess's Avatar
Question accelerator sticking - almost blew up my engine
When I started my screw this morning, the accelerator stuck, and it sounded like the engine was so revved it was going to blow up. Had to shut off the truck, and restart, and the same thing happened, shut off, and started again and it slowly returned to normal ? Any one else with this problem ?
Old Mar 12, 2001 | 11:19 AM
Maximum Overdrive's Avatar
Post
check this.. Full story of things like this happening to our horsepower freak friend Neal!
https://www.f150online.com/f150board...ML/002029.html
1997 F-250LD Super-Cab Styleside 4x4
  • Bright Red Clearcoat Metallic
  • 5.4/L V-8
  • Heavy-duty everything
  • 3.73 Rear End
  • Manual 4x4 floor shift for increased reliability
  • Soft tonneau cover
  • All-Star Bedliner
  • 5th Wheel Hitch
  • Keepin it stock! ;-)
Future Mods:
  • Superchip
  • Goodyear Wrangler AT/S Tires
  • K&N FIPK
  • Super-White Headlights (when the current ones go bad)
  • Lighted Ford Logo for the front Grille
  • Ford Hitch Cover
  • In-dash CD reciever, upgraded speakers
Other Toys:
  • 1994 Kawasaki Bayou 220
  • 1997 Yamaha Zuma-II Scooter
  • 1978 Arctic-Cat Jag 3000 F/A
My Collection of Funny Pictures and other Various Humor related items!
Contact:
rockerc@mediaone.net
AND
on AOL: LeAdFoOt415
Old Mar 12, 2001 | 11:31 AM
Raoul's Avatar
Certified Goat Breeder
25 Year Member
Post
This probably didn't happen to you. I only post it because the Topic is so similiar.
https://www.f150online.com/f150board...ML/000751.html
Old Mar 12, 2001 | 05:16 PM
Neal's Avatar
Cool
HI!... MAXIMUM OVERDRIVE : Welcome to the boards! I see that you live in PLYMOUTH, MICHIGAN. Mabey you would be interested in attending our "MILAN MEET" at MILAN DRAGWAY on APRIL 14TH. It's a test and tune day, and you can meet some of your fellow F-150'ers here and mabey see what your truck will do in the 1/4 mile. Let me know if your interested in attending under the "EVENTS AND HAPPENINGS" thread. Thanks.
NEAL " THE H.P FREAK" E-MAIL :nnewman@sympatico.ca
'99' F-150 XLT SPORT, oxford white, reg cab shortbox stepside,5.4, auto, 4.10L.S, captain's chairs, bedliner, GTS carbon fiber headlight covers, ***** CEPECK clear halogen driving lights, GTS slotted tailight covers (painted oxford white), fiberglass smooth wiper cowl (painted OXFORD WHITE), FORD locking lug nuts, tinted windows,true duel exhaust with 2.5 inch mandrel bent pipes and FLOWMASTER 3 chamber mufflers with 3' tailpipes exiting before the rear wheel like the LIGHTNING, HELLWIG rear stabalizer bar, 3 AUTOMETER guage pods, filled with tranny temp, engine temp, and oil preasure AUTOMETER "PHANTOM" guages,custom fabricated air intake trac and huge K/N filter, TPS mod, BELLTECH 2-inch rear drop, custom programed SUPERCHIP, BAUMANN ENGINEERING shift kit (on stage 5 setting)BYPASS CLUTCH CONTROL VALVE/PREASURE REGULATOR VALVE, ASP POWER PULLEYS, custom tig welded and ported JBA "JET BLACK coated headers, twin DERALE 16 INCH ELECTRIC FANS, PERMA COOL 14"/10" tranny cooler with 10" electric fan, custom ported (STOCK) throttle body, custom digital air intake temp sensor, custom ported TB intake elbow, relocated ATS.
FUTURE MODS : FORD SVT 24LB INJECTORS, CUSTOM SUPERCHIP FLIP-CHIP, BBK 75MM THROTTLE BODY, 80MM PRO-M MASS AIR METER, AADI F1 RAM AIR HOOD WITH CUSTOM FABRICATED RAM AIR SET-UP, CAL-TRAC TRACTION BARS, EXTRUDE HONED INTAKE MANIFOLD, SHM CUSTOM FUEL RAILS, SHM "RACE WATER PUMP, 90/10 FRONT CE SHOCKS, 70/30 REAR CE SHOCKS, BELL TECH 2/4 DROP, EXPEDITION CENTER CONSOLE, HARLEY DAVISON F-150, LOWER FRONT VALANCE (painted oxford white) and a KENNE BELL BLOWZILLA SUPERCHARGER.
ESTIMATED H.P TO DATE : 330H.P / 425ft/lbs of torque.
CURRENT PERFORMANCE : 1/4 MILE - 14.53E.T * MPH - 93.00 * 0-60MPH - 5.8 * 1/8 MILE - 9.2 * 60 FT - 2.0
OTHER TOYS : "83" PRO STREET FORD RANGER : 351-w stroked to 408c.i 625H.P (natural), 875H.P with 250H.P "BIG SHOT" N.O.S kit, tubbed (crome moly tubing), 12 point chrome moly roll cage, 4-link with coil overs, MUSTANG II front suspension, c-4 tranny (race prepped), 4000rpm stall converter(8 INCH), 3" chrome moly driveshaft,AUTOMETER guages, 15.50 MICKEY THOMPSON rear tires, 4" M/T front tires, CENTERLINE CON-VO PRO rims, fiberglass hood - bumper - prostock hood scoop, wishbone trac-link, two chrome moly driveshaft loops, 16 gallon RCI fuel cell,etc
Old Mar 13, 2001 | 12:23 AM
dgreene's Avatar
Post
i installed a bbk 75mm throttle body on my '97, 4.6 f-150 recently. easy install btw. then went for a test drive...after warm-up, i nailed it...stuck throttle--wide open! turned engine off and braked over to side of road. started back up--ran normal? checked th. body, cables, spring, th. plate--everything normal. throttle plate would not bind. still haven't nailed it again. don't think it was floor mat but will take it out just in case.
Old Mar 14, 2001 | 12:48 AM
captainoblivious's Avatar
Post
Maximum Overdrive - I like your signature pictures. Try NJ some time, we just have traffic, at least you have a reason.
Old Mar 14, 2001 | 01:47 AM
EeyoreLives's Avatar
Post
Hello,
I have a 2001 Expedition and I have twice experienced my accelerator getting stuck. Luckily the accelerator released itself after one or two seconds. Both times were while on the freeway and both occured when I had the accelerator fully pressed trying to go up an incline. When it happened the first time, I thought my cruise control had inadvertently engaged itself. Another thought was my floor mat may have gotten caught, but now I think the problem may be correlated with my new high flow air intake system I had installed. The reason I think the two may be correlated is because I had never experienced this problem with the vehicle before having the air intake installed. Does anyone know if this is possible?
Old Mar 14, 2001 | 09:00 AM
Post
Well hey guys. Neal: Hey what up?! Sorry bro cant go there that day I got school and my b-day is the next day (Easter :-) ) ...
  • 5.4/L V-8
  • 3.73 Rear End
  • All-Star Bedliner
  • 5th Wheel Hitch
Future Mods:
  • Superchip
  • K&N FIPK
  • Ford Hitch Cover
Other Toys:
Contact:
AND
on AOL: LeAdFoOt415
