Dead in the water
Old Mar 4, 2001 | 09:25 AM
fplus's Avatar
Red face Dead in the water
My F 250 , with a 300 cuin 6 died on the driveway while plowing this week. Ether doesn't get a pop of it. Gas is ok, seems to have no spark. Seems this happened once before and the mechanic replaced a small rectangular module on , in, or near the distributor. Anyone hlp with this? It's goning to snow again today. Thanks, Larry.
Old Mar 4, 2001 | 02:59 PM
2000Black's Avatar
Post
Sounds like you are talking about a TFI module. TFI means thick film integration. It's pretty easy to swap out. Pick up some dielectric grease when you get the part. This usually only causes it to stall when hot. It should start up cold unless this has been going on for a while.
2000 Black Lightning
#1326 of 4966
Born on 03/20/2000
PSP Chip
PSP Filter
Best time: 13.335 @ 103.91 mph
Old Mar 4, 2001 | 04:03 PM
Dennis's Avatar
Post
Didn't California or some other state sue Ford to get them to recall all the vehicles that used this?
Check with your local dealer. There may be a recall on this and the cost of repair could be covered.
Old Mar 4, 2001 | 06:37 PM
fordtec2001's Avatar
Post
i think its still in court here in ca for the recall
but iwould also check the stator inside the distb. as well if the tfi mod. got hot then most likely the stator did too if its soft where the tfi connects to the stator then its bad too
Old Mar 4, 2001 | 07:35 PM
2000 F150 4x4's Avatar
Cool
The TFI gets hot as hell in the stock location. If you want a beter setup, go with a setup like the SN95 Mustangs have. The TFI is located away from the ditributor and engine and is encased in a nice heat sink unit.
2000 F150 XLT 4x4 Short Bed. Amazon Green, 5.4L, SuperCab, ORP, Tow Package, Sliding Rear Window, Electronic Shift, Keyless Entry, LT265-70-17 Tires, Clarion Pro Audio, Herculiner Bedliner, Air Silencer Removed.
1994 SVT Mustang Cobra. #1032 of 6009. Black coupe with black leather int., 3.73 rear, Bassani Exhaust, Aluminum D/S, Bridgestone RE-71 255-45-ZR17
My Home Page
