What oli do you guys use?
Old May 11, 2002 | 12:17 AM
Boltittome's Avatar
Cool
Castrol Syntech 5w-30 and 820s, that is daily driven with as many HIGH SPEED back road runs i can get in 2000 Lightning,,
Old May 11, 2002 | 01:19 PM
doorslammer69's Avatar
Smile
Amsoil 0W30 and SFD 11 filter. Amsoil products throughout, including PI in the gas.
Old May 11, 2002 | 01:22 PM
2002gray-ghost's Avatar
I guess I'm not too original...
Motocraft 5w-20 Syn Blend
Motorcraft filter
just like the owner's manual says...
Old May 11, 2002 | 05:48 PM
Rick99's Avatar
Registered User
Originally posted by BAJANBLACK
I use Royal Purple 5w30 synthetic Oil with K&N Gold Filter (with the 1" nut for easy removal).
I have had no oil related issues since switching from Dino oils but to be honest, I am not so sure that there is that much of a difference in my trucks performance.
Baj
How much per quart is the Royal Purple.
Old May 11, 2002 | 06:31 PM
msparks's Avatar
Amsoil Of Coarse,
Series 2000 0w30. Amsoil dual remote with an SDF 26 and a BE110. Total of 9 quarts oil capacity!!!
Old May 12, 2002 | 10:10 PM
Talleywacker's Avatar
Suspended For Violation of Vendor Rules
Royal Purple 0w-30 synthetic w/ Motorcraft filter... usually Mobil 1 filter, but they were out this oil change. I can get Royal Purple for $5.49/qt.
Old May 13, 2002 | 01:52 PM
DeaconDoug's Avatar
5w-30 Mobil 1 tri-synthetic and motorcraft fl-820 filter.
Old May 13, 2002 | 03:17 PM
LIGHTNINROD's Avatar
Rick99:
For their Racing oil(what I use)
http://www.jegs.com/cgi-bin/ncommerc...05&prmenbr=361
Here is their 'Street' oil
http://www.jegs.com/cgi-bin/ncommerc...07&prmenbr=361
Dan
Old May 13, 2002 | 08:45 PM
Neil's Avatar
25 Year Member
Post
I'm using Chevron Supreme 5w-30 and the Motorcraft 820 filter.
Old May 13, 2002 | 09:57 PM
hades281's Avatar
Castrol GTX 5w-30
Motorcraft FL-400S (v6) Filter
My brother and I use Castrol... his truck (Chev 4.3) is run very hard on a daily basis and is now at 200,000 miles without any oil related problems. Its made a believer out of me.
I also agree that the Motorcraft filter is a good one. I always hear bad stuff about Fram.
Old May 14, 2002 | 12:55 PM
two-rocks's Avatar
A good read on oil filters
http://minimopar.net/oilfilterstudy.html
An interesting read. Seems to be reproduced on many different sites...
I'm waiting for the Amsoil (re-badges Hastings I think) to get published...but I'm not sure the page gets updated anymore.
-Greg
Old May 14, 2002 | 01:37 PM
mudd1's Avatar
use mobil1 and motorcraft filter and u will be fine
Old May 15, 2002 | 08:01 PM
KT's Avatar
KT
Well not sure if you are looking for suggestions
or not but this subject seems to boil down to
personel preferance or what ever will give you
peace of mind because if changed often enough
3,000-5,000mi most oils that are SAE&API rated
will do the trick. As far as which oil is best you
ask 10 people you will probably get 10 diffrent
opinions and most likely to notice a diffrence
you would need to tear the engine down once
a year or so to verify any diffrence in protection
from one brand or another, Or believe what the
manufacturer says their oil will do. For me i use
Mobil 1 5w30 not because i have proof it's better
it's just what i chose to run, My previous truck
was a 1990 Chevy 5.7L and i used nothing but
Valvoline 10w30 and sold it at 190,000 mi with
no problems and bought my 2000 F150 and at
58,000 mi have had no problems with it.
Bottom line use what you wish and follow at
least Fords recommended change frequency
and drive.
Old May 15, 2002 | 09:06 PM
f-150_91's Avatar
02 laser,
Whem using 0w30 how well does it protect while driving on 90 degree heat???????? Also how is your mileage, performance and all that. BTW, I use AMSOIL 5w30 and SDF filter. My truck seems ok with this.
Old May 15, 2002 | 09:43 PM
TexfordD's Avatar
oil and filter
motorcraft filter and quaker state 5w30,10w30,10w40 as it heats up down here,5 years now,no problems,no leaks,no smoke,75000 miles,change out every 2000-2500 miles.
