Lightning Heads for a 4.6L
HI!...SPEEDER : The stock 5.4 heads should give you a gain of about 25H.P. The stock injectors will work with these heads. You will have to run 5.4 "99" cams with these heads and use the 4.6 cam gears. From what I have been told by many sources is that the 5.4 cams have more duration than the 4.6 cams do.Hope this helps you out.
NEAL " THE H.P FREAK"
'99' F-150 XLT SPORT, oxford white, reg cab shortbox stepside,5.4, auto, 4.10L.S, captain's chairs, bedliner, GTS carbon fiber headlight covers, ***** CEPECK clear halogen driving lights, GTS slotted tailight covers (painted oxford white), fiberglass smooth wiper cowl (painted OXFORD WHITE), FORD locking lug nuts, tinted windows,true duel exhaust with 2.5 inch mandrel bent pipes and FLOWMASTER 3 chamber mufflers with 3' tailpipes exiting before the rear wheel like the LIGHTNING, HELLWIG rear stabalizer bar, 3 AUTOMETER guage pods, filled with tranny temp, engine temp, and oil preasure AUTOMETER "PHANTOM" guages,custom fabricated air intake trac and huge K/N filter, TPS mod, BELLTECH 2-inch rear drop, custom programed SUPERCHIP, BAUMANN ENGINEERING shift kit (on stage 5 setting)BYPASS CLUTCH CONTROL VALVE/PREASURE REGULATOR VALVE, ASP POWER PULLEYS, custom tig welded and ported JBA "JET BLACK coated headers, twin DERALE 16 INCH ELECTRIC FANS, PERMA COOL 14"/10" tranny cooler with 10" electric fan, custom ported (STOCK) throttle body, custom digital air intake temp sensor, custom ported TB intake elbow, relocated ATS.
FUTURE MODS : FORD SVT 24LB INJECTORS, CUSTOM SUPERCHIP FLIP-CHIP, BBK 75MM THROTTLE BODY, 80MM PRO-M MASS AIR METER, AADI F1 RAM AIR HOOD WITH CUSTOM FABRICATED RAM AIR SET-UP, CAL-TRAC TRACTION BARS, EXTRUDE HONED INTAKE MANIFOLD, SHM CUSTOM FUEL RAILS, SHM "RACE WATER PUMP, 90/10 FRONT CE SHOCKS, 70/30 REAR CE SHOCKS, BELL TECH 2/4 DROP, EXPEDITION CENTER CONSOLE, HARLEY DAVISON F-150, LOWER FRONT VALANCE (painted oxford white) and a KENNE BELL BLOWZILLA SUPERCHARGER.
ESTIMATED H.P TO DATE : 330H.P / 425ft/lbs of torque.
CURRENT PERFORMANCE : 1/4 MILE - 14.53E.T * MPH - 93.00 * 0-60MPH - 5.8 * 1/8 MILE - 9.2 * 60 FT - 2.0
OTHER TOYS : "83" PRO STREET FORD RANGER : 351-w stroked to 408c.i 625H.P (natural), 875H.P with 250H.P "BIG SHOT" N.O.S kit, tubbed (crome moly tubing), 12 point chrome moly roll cage, 4-link with coil overs, MUSTANG II front suspension, c-4 tranny (race prepped), 4000rpm stall converter(8 INCH), 3" chrome moly driveshaft,AUTOMETER guages, 15.50 MICKEY THOMPSON rear tires, 4" M/T front tires, CENTERLINE CON-VO PRO rims, fiberglass hood - bumper - prostock hood scoop, wishbone trac-link, two chrome moly driveshaft loops, 16 gallon RCI fuel cell,etc
