Mobil1 0W-30
Old Apr 27, 2002 | 05:06 PM
CodeBlue's Avatar
Mobil1 0W-30
I on my last oil change I switched to Mobil1 Tri-Synthetic 5W-30. I am about to change my oil agian. I was wondering if anybody was running the 0W-30 instead of there 5W-20 or 5W-30 recommended by Ford. I was also going to go to the NEW Mobil1 SuperSyn 0W-30. I would like anybody's opinon.
Old Apr 27, 2002 | 05:26 PM
davidzog's Avatar
I emailed Mobil when I bought my 2001 Supercrew. I asked them about using a synthetic, and about 5w20. They indicated that 0w30 was closest in viscosity to the 5w20 and that it would be a good substitute....better that 5w30. So, I went with it and have had no trouble in 9,000 miles....I change at 4,000
Old Apr 27, 2002 | 10:47 PM
F150Forever's Avatar
If you look at the reccomendations on the Mobil 1 web site, for Mobil 1 with "SuperSyn", they are marketing the 0w-30 for cold climates, 0w-40 for European engines, 5w-30 for newer vehicles, 10w-30 for higher-mileage vehicles, and 15w-50 for high performance vehicles.
I think the choice between 0w-30 and 5w-30 is a toss-up as long as you don't live in Alaska. Just my $0.02.
Old Apr 27, 2002 | 11:26 PM
Dick 4's Avatar
Your 0.02 cents is worth alot
I agree, neither one will harm your engine.
How much more is that Mobil Super Syn?
Old Apr 27, 2002 | 11:36 PM
I paid the same at Walmart as I used to pay for the old Mobil 1 - $3.74 / qt. Sometimes Walmart has the 5 qt. economy jug for $17.88 here in So. FL.
Old Apr 28, 2002 | 03:31 AM
MN4x4's Avatar
Same here up in MN. All Mobil 1 is the Super Syn now. Better stuff...same price.
Old Apr 29, 2002 | 09:37 AM
CodeBlue's Avatar
I bought the 0W-30 and on the bottle it stated. "Enhanced Fuel Economy Formula". Also since that spec that Ford created for 5W-20 can only be achieved by 5W-20 oil could that standard have applied to only 5W-20 oil. In other words if you use a 5W-20 oil it must meet that spec? Hmmmmmmmm.
Old Apr 29, 2002 | 10:40 AM
acadianbob's Avatar
mobil 1 is great oil. i have used it for years with great results. i don't remember whether AR is arizona or arkansas or what but if you live in a warm climate, you don't need 0W-30. 5W-30 might be better as it will hold its "warm" viscosity better. that is because the base stock is 5 weight and it takes fewer polymers to make it get to 30 weight when hot. the polymers wear out as oil ages. so i'd do 5W-30 for that reason.
Old Apr 29, 2002 | 02:02 PM
davidzog's Avatar
I was under the impression that the higher the viscosity index number, the better the protection....
If you look at the specs for Mobil1 on their website, 0w30 has a higher viscosity index than 5w30 or 10w30.....
Interesting....................................... .
Old Apr 30, 2002 | 09:03 AM
msparks's Avatar
Viscosity Index is only useful in comparing oils of the same weight. So a 0w30 will have a lower viscosity index comparitivley than a 10w30.
To quote from the Lubrizol site:
To compare petroleum base oils with respect to viscosity variations with temperature, ASTM Method D 2270 provides a means to calculate a viscosity index (VI). This is an arbitrary number used to characterize the variation of kinematic viscosity of a petroleum product with temperature. The calculation is based on kinematic viscosity measurements at 40 and 100°C. For oils of similar kinematic viscosity, the higher the viscosity index, the smaller the effect of temperature.
As you see the comparison is between oils of similar kinematic viscosity
Old May 1, 2002 | 08:50 PM
davidzog's Avatar
I am not sure I understand....
Are you saying that if 0w30 has a VI of 172 and 5w30 has a VI of 167, there is no comparison because they are different grades????
I guess I am confused, as it makes sense that a heavier oil would understandable have a higher VI.
I get the fact (I think) that if one 5w30 has a higher VI than another 5w30 that the first oil would provide more protection...
So how does one compare various weights to deterime the best oil for their application????
