Thread Size
Old Feb 2, 2001 | 05:01 PM
LARIAT1's Avatar
From: INDIANA,.....USA " Where more than Corn grows in Indiana"!!!
Question Thread Size
Does anyone here know the size of the thread for the stock oil filter? The I.D. of the filter. I know that it is in mm. But what??? Any help would be helpful!!!! Thanks,
Lariat#1
1997 Red/Silver F150 Lariat Flareside 3 Dr. SC.....
ORP & Tow Package Complete Lariat Option Package
{APPEARANCE}
GTS Projector Beam /Carbon Fiber Headlight Covers
AVS Tail Lights Slots
Door Sill Protectors
Flareside tail lights wired to work upper & lower lenses together
Owens Fiberglass Step Boards
Custom Tinted Windows
Ford 2-Piece Bra
Lighted Ford Logo in Grill
20" Chrome Exhaust Tips
A.R.E Bed Cover Lid
Pendaliner Inner Tail Gate Protector
Zie-Bart Total Paint & Under Coating W/ Sounder Deadener Protection
Lariat #1 Plate under glass on Front Bumper
Custom made Ford Red Window Decals
Blue Tinted Rear Lic. Plate Protector
Ford Lited Hitch Receiver Cover that works off brakes lights
Heavy Duty Bed Mat
Red reflectors above Rear Bumper
{PERFORMANCE}
4.6L WINDSOR
Auto Trans
3.55 LS
4-Wheel ABS
Platinum 3 Spark Plugs
K&N Air Filter W/ modified stock MAF side air box
Outerwears Blue Pre-Filter Cover
Tornado Air Man.
Perma-Cool Oil Filter Relocation Kit
Motorcraft Racing Oil Filter FL-1HP
Fumoto Oil Drain Valve F-106
Dual Exhaust System W/Stock Muffler
NAPA Ceramix Carbon Ceramic Premuim Brake Pads(Front)
17" Goodyear Wrangler A/TS Tires
55 Watt Halogen(replacement) Reverse Lights
Pilot 55 watt Halogen (add-on) Reverse Lights on Hitch under truck
Driving Lamps upgraded to 55 Watt Cool Blue Halogen Bulbs
Pilot Bright Whites headlite bulb replacements 65/55 watts
Driving Lamps(Foglites) work W/ High Beams On & Driving Lamps(Foglites) also work (ON or OFF) W/ Park Lamps On W/Switched Relay
A.R.E Cover wired W/interior(dome) light wired to a mounted door jam switch thats wired to hood light
SurgeGuard by Calterm
{AUDIO} Stock In-Dash Cass. W/6 Disc Changer & 2 Stock Speakers(back)
2 Pioneer TS-A6865 3- Ways(front)
Black Felted Inner Front Door Speaker openings All Speakers Dynomat Lined
Trenz Billet #3 Antenna
{SECURITY}
Ford Total Security System W/ Motion Alarm All on factory Key Fob
Ford Warning Decals on Windows
A.R.E Cover & Hood also wired to Alarm System Hitch Pin locking system
This is LARIAT#1..... IN The Great State Of Indiana "Where more than corn grows in Indiana".
........http://hometown.aol.com/terrylariat1...page/auto.html A Very Proud Member of ...www.f150online.com
Future Mod.`s.......
Soon to have Flareside Rear Step Bumper re-plated (Triple Chrome Plated)
Old Feb 3, 2001 | 02:51 AM
Neal's Avatar
Cool
HI!... LARIAT1 : The oil filter thread is standard. It's 3/4-16 thread. 99% of FORD engines use this thread size on their blocks and oil filters. Hope this helps you out.
NEAL " THE H.P FREAK"
'99' F-150 XLT SPORT, oxford white, reg cab shortbox stepside,5.4, auto, 4.10L.S, captain's chairs, bedliner, GTS carbon fiber headlight covers, ***** CEPECK clear halogen driving lights, GTS slotted tailight covers (painted oxford white), fiberglass smooth wiper cowl (painted OXFORD WHITE), FORD locking lug nuts, tinted windows,true duel exhaust with 2.5 inch mandrel bent pipes and FLOWMASTER 3 chamber mufflers with 3' tailpipes exiting before the rear wheel like the LIGHTNING, HELLWIG rear stabalizer bar, 3 AUTOMETER guage pods, filled with tranny temp, engine temp, and oil preasure AUTOMETER "PHANTOM" guages,custom fabricated air intake trac and huge K/N filter, TPS mod, BELLTECH 2-inch rear drop, custom programed SUPERCHIP, BAUMANN ENGINEERING shift kit (on stage 5 setting)BYPASS CLUTCH CONTROL VALVE/PREASURE REGULATOR VALVE, ASP POWER PULLEYS, custom tig welded and ported JBA "JET BLACK coated headers, twin DERALE 16 INCH ELECTRIC FANS, PERMA COOL 14"/10" tranny cooler with 10" electric fan, custom ported (STOCK) throttle body, custom digital air intake temp sensor, custom ported TB intake elbow, relocated ATS.
FUTURE MODS : FORD SVT 24LB INJECTORS, CUSTOM SUPERCHIP FLIP-CHIP, BBK 75MM THROTTLE BODY, 80MM PRO-M MASS AIR METER, AADI F1 RAM AIR HOOD WITH CUSTOM FABRICATED RAM AIR SET-UP, CAL-TRAC TRACTION BARS, EXTRUDE HONED INTAKE MANIFOLD, SHM CUSTOM FUEL RAILS, SHM "RACE WATER PUMP, 90/10 FRONT CE SHOCKS, 70/30 REAR CE SHOCKS, BELL TECH 2/4 DROP, EXPEDITION CENTER CONSOLE, HARLEY DAVISON F-150, LOWER FRONT VALANCE (painted oxford white) and a KENNE BELL BLOWZILLA SUPERCHARGER.
ESTIMATED H.P TO DATE : 330H.P / 425ft/lbs of torque.
CURRENT PERFORMANCE : 1/4 MILE - 14.53E.T * MPH - 93.00 * 0-60MPH - 5.8 * 1/8 MILE - 9.2 * 60 FT - 2.0
OTHER TOYS : "83" PRO STREET FORD RANGER : 351-w stroked to 408c.i 625H.P (natural), 875H.P with 250H.P "BIG SHOT" N.O.S kit, tubbed (crome moly tubing), 12 point chrome moly roll cage, 4-link with coil overs, MUSTANG II front suspension, c-4 tranny (race prepped), 4000rpm stall converter(8 INCH), 3" chrome moly driveshaft,AUTOMETER guages, 15.50 MICKEY THOMPSON rear tires, 4" M/T front tires, CENTERLINE CON-VO PRO rims, fiberglass hood - bumper - prostock hood scoop, wishbone trac-link, two chrome moly driveshaft loops, 16 gallon RCI fuel cell,etc
Old Feb 3, 2001 | 11:24 PM
LARIAT1's Avatar
Exclamation
This is wrong!!!!! Neal....All new trucks 1997 & up have a mm thread not standard. I know this much as fact. What you posted is for all older trucks 96 & down. The FL-820S filters have a larger thread size. I`m thinking its 18 mm but not sure of this. Is there anyone that has the right thread size out there???????
Lariat#1
{APPEARANCE}
Ford 2-Piece Bra
A.R.E Bed Cover Lid
Heavy Duty Bed Mat
{PERFORMANCE}
4.6L WINDSOR
Auto Trans
3.55 LS
4-Wheel ABS
Tornado Air Man.
{SECURITY}
Old Feb 4, 2001 | 02:01 AM
Neal's Avatar
Cool
HI!... Well LARIAT1 : I might be wrong but the oil filter from my "79" 351-W screws right on to my "99" 5.4L. I should know, it;s on there right now.lol!
Old Feb 4, 2001 | 02:50 AM
LARIAT1's Avatar
Question
Neal.....tell me what the oil filter part # is for your 99 5.4L if it is FL-820S there is no way it would fit a 79 351 W. Unless you are using a oil filter Relocation kit on your 99.Which most go back to the older style filter size. The new style is mm which I don`t know which it is 18 mm, 20.5 mm,or 22.5 mm .Do you put your filter on the block?????? Or on the Frame???
Lariat#1
{APPEARANCE}
Ford 2-Piece Bra
A.R.E Bed Cover Lid
Heavy Duty Bed Mat
{PERFORMANCE}
4.6L WINDSOR
Auto Trans
3.55 LS
4-Wheel ABS
Tornado Air Man.
TD Performance Oil Filter Relocation Kit
{SECURITY}
Old Feb 4, 2001 | 01:44 PM
Neal's Avatar
Cool
HI!... On the block.
Old Feb 4, 2001 | 01:52 PM
msparks's Avatar
Post
Specifications,
Diameter: 3.72inches, Height: 3.966inches
Thread size: 22 X 1.5mm
Gasket I.D: 2.46 inches
Gasket O.D: 2.81 inches
By-pass valve: 7-9 PSID
Anti-drainback valve: yes
This is for Amsoil's SDF11 which I use in my 97F150 4.6L
Hope this helps,
Lube-Direct
New Lubrication Forums
Old Feb 4, 2001 | 03:45 PM
JMC's Avatar
JMC
25 Year Member
Post
L1,
If you want to be 100% sure take your filter down to the local hardware store and try all the bolts that seem to fit. Start with msparks size first as it would save a lot of time looking. BTW why the question?
Regards
Jean Marc Chartier
Old Feb 4, 2001 | 07:19 PM
LARIAT1's Avatar
Thumbs up
Hey Thanks, msparks i knew it was 18,20 or 22 mm. This helps alot!!!! Its 22x1.5 mm . I had a 1/2 pipe thread & it even screwed into it. But the thread in the stock filter is finer.The 1/2 pipe is courser.On my new relocation kit by TD Perfomance , the base where the filter goes now is the old style 3/4 16 thread. So now I`m using the full size filter Ford`s FL-1HP or Purolator`s HP1. I may try PureOne next.
Lariat#1
{APPEARANCE}
Ford 2-Piece Bra
A.R.E Bed Cover Lid
Heavy Duty Bed Mat
{PERFORMANCE}
4.6L WINDSOR
Auto Trans
3.55 LS
4-Wheel ABS
Tornado Air Man.
{SECURITY}
Old Feb 4, 2001 | 07:32 PM
LARIAT1's Avatar
Red face
JMC, the reason for the question to be sure, because I was going to get the filter(frame )Adapter that Ford has on most 4x4`s. But I found out after my posting that just the adapter from Ford is $128.00. So I will stay with the after market one !!!! The TD Perfomance Relocation Kit was only $40.00. I got from Summit Racing. Thanks for asking!!!!
Lariat#1
{APPEARANCE}
Ford 2-Piece Bra
A.R.E Bed Cover Lid
Heavy Duty Bed Mat
{PERFORMANCE}
4.6L WINDSOR
Auto Trans
3.55 LS
4-Wheel ABS
Tornado Air Man.
{SECURITY}
