5.4L using oil
Old Jan 16, 2001 | 08:11 AM
JSCOTT's Avatar
Post 5.4L using oil
I have a 98 5.4L that now has 39K on it. I bought it new and changed to Mobil 1 5W-30 at 1000 miles. I am NOT trying to start a debate on synthetic vs conventional oil. The truck has always used maybe 1/2 at oil 5000 miles changes. I am now at 4000 miles, and it was 3/4 qt low. If I run some conventional oil for 3000 miles, will that seat the rings, etc and reduce/eliminate my oil usage? Is it too late?
Forgot to mention...The other day, I had driven home (5 miles) where it was cold and rainy. When I pulled in the driveway, the engine started running real rough. The exhaust also smelled. I turned it off and then back on and it has been fine since. This is the first time anything like this has happened. Bad gas maybe?
Thanks,
1998 F-150 XLT SC 5.4L
[This message has been edited by JSCOTT (edited 01-16-2001).]
Old Jan 16, 2001 | 07:13 PM
Dunbarton's Avatar
Post
JSCOTT,
Relax ........ a quart or less in 4,000 miles is not a problem at all. I wouldn't change to petro now to attempt what you want to do. At 39,000 miles whatever you have is what will remain. In my opinion you don't have a problem at all.
Have you had your fuel filter changed lately?
Dunbarton "The Middle Aged Kid" '99 XLT SC SB 4x2 4.6 auto 3.55 ls The occasional Z-71 Eater! Wedgewood & Denim, SuperChipped, Airaid FIPK, HD electrical and cooling, power seat, Rhino Liner, Extang Classic tonneau cover, Mobil 1. Man, I got it all! (New Jersey)
Old Jan 16, 2001 | 08:42 PM
JSCOTT's Avatar
Post
My concern is that the usage is increasing. It used to only use a half quart or so in 5000 miles. I changed the fuel filter at 30K.
