Amsoil bypass filter
Old Jan 9, 2001 | 11:29 AM
lerdman's Avatar
Question Amsoil bypass filter
Is anyone using an Amsoil bypass oil filter? I was wondering, where is a good place to mount the remote filter. Under the hood is pretty tight.
Old Jan 9, 2001 | 11:03 PM
msparks's Avatar
Post
Best place is behind the transmission on the frame rail. Most folks have to have a special bracket made. But this location has easy acess, plus you can mount it vertically. And its very protected since it is mounted higher than the transission crossmember!
I have access to premade brackets for about $44 bucks. Also when you mount the by-pass you will want to order 90degree elbows to come off of the adapter plate since the lines will be coming straight back towards the transmission.
Email me for more information
Lube-Direct
New Lubrication Forums
[This message has been edited by msparks (edited 01-09-2001).]
