Second 4.2l engine trouble
Old Jan 6, 2001 | 06:27 PM
mytruck1's Avatar
Question Second 4.2l engine trouble
Please help! I'm on my second 4.2l engine and now I'm noticing a white residue on the bottom of my oil cap. This is similar to what I saw when my engine died the first time. The dealer checked it out and said my pcv valve was stuck open and allowing moisture in. 143 miles later (with new oil) I'm seeing the residue still. Anyone else notice this??? I have quite a story about my first engine but I'll save that for some other time, Thanks in advance for any help.
Old Jan 6, 2001 | 10:28 PM
RILOATM's Avatar
Thumbs up
Let me be the first to welcome you to the F150 Online message board.
Wow, a problem with the 4.2L engine. So far, besides coolant leaks / gasket problems I haven't heard any complaints about the v6. Try posting in the V6 board, you'll get a lot of help there. Be sure to keep us posted.
~¤Mark¤~
¤1999 F-150 supercab w/ a big ole 4.2L
¤BFGoodrich 265/75R's
¤16" Eagle Alloys series 589
¤Billet Alluminum Grille
¤Pioneer DEH-P9200
¤800 Watt Power Acoustik Fire and Ice Amplifier for the XLC's
¤2400 Watt Power Acoustik "1 Ohm series" for the Power DVC's
¤2 10" Punch XLC's
¤2 12" Punch Power DVC's
¤Custom Door Poppers
¤Power locks...etc..etc
Fightin Texas Aggie Class of '02 WHOOP!
Old Jan 6, 2001 | 10:31 PM
j.b.'s Avatar
Post
mytruck: I understand your concern after having an engine replacement. I believe what you are seeing however is normal for this time of year. Condensation can form on the inside of anything which has been heated up and then allowed to cool in cold, damp weather. Would suggest looking at the cap after an extended trip where the engine has been allowed to heat up enough to evaporate the moisture out of the oil. If it is of any consolation, I have had many VW air cooled Beetles which always could be counted on to have the white foam under the cap, caused by stop and start driving in the winter months. It was often hard to get them up to operating temps when the weather was at 10 degrees or so, and most of trips were in town driving. If your antifreeze level is staying the same, don't sweat it yet...Spring will be here soon! j.b.
99 SC Sport, Silver color everywhere, 4.2 auto,3.55 rear gear, split bench, stock AM/FM @ 2 cheesy speakers w/Ford brand bedliner. Keep'n stock from the factory because we love it for what it is...One fine ride!
