squeak when cold
Old Mar 24, 2002 | 11:12 PM
blove's Avatar
squeak when cold
i have a 99 5.4. when it is cold outside and i start my truck in the morning, there is a squeaking sound. i have heard that it might be the belt tensioner. it goes away after about 5 minutes. any ideas of what it might be?
Old Mar 24, 2002 | 11:29 PM
hmustang's Avatar
My 4.6 does it from time to time in the cold always figured it was the belt or one of the pulleys.
Old Mar 25, 2002 | 03:13 AM
KYFordFreak's Avatar
Could be the belt, the belt tensioner, or possibly the fan clutch. A thermo-type fan clutch is nothing more than a fluid coupling. If the fan clutch is bad and leaked all the fluid out or maybe if it was cold enough the fluid is actaully thick and the 5 minutes is enough to thraw it up enough to silence the squeal. I might be way off base, anyone else care to disprove or improve on my idea.
Old Mar 25, 2002 | 09:40 AM
Silent Bob's Avatar
I have had problems with squealing. I've had the belt replaced a couple of times, and tensoner, ildlers. I finally stumbled upon the noise by taking the belt loose and turning all the accessory pulleys by hand.
