engine flush?
my 2000 f150 has 1000 miles on it now. after first oil cahange i want to go to synthetic. why in the world would i need to flush the engine and what if any benefits would i receive? is 3k miles enough towards breakin to change to synthetic? or should i put more miles on it then change. 2k f150 xtra cab 4x4 5.4l lariat
I put three qts reg oil and three qts synny in. Next time it will be six qts synny. By the 2nd synny oil change comes around, your engine will be "flushed" naturally.
1999 F-150, SCab, 4x4, 5.4, auto
I have switched to synthetic at the first oil change on many vehicles(never flushing,never a problem), I prefer to break in with conventional oil and to get full use of it as well. My opinion only, Good Luck !!
2000 F-150 XL, RC, LB, 5.4L, 4R70W, 3.55LS,
Class III tow, Payload #3, & Convenience pkgs.,
4-wheel disc/ABS, Chestnut/Parchment 40/60,
Ford bedliner w/Paintsaver & gas/wheel/spare locks,
K&N F.I.P.K. w/Outwears pre-filter, Superchip,
Dynomax ultra-flow welded 3" cat-back w/ 3" Y-pipe,
Hellwig front & rear anti-sway bars, Rancho RS 9000s,
Mobil 1, K&N oil filter.
<font face="Verdana, Arial" size="2">Originally posted by mud:
my 2000 f150 has 1000 miles on it now. after first oil cahange i want to go to synthetic. why in the world would i need to flush the engine and what if any benefits would i receive? is 3k miles enough towards breakin to change to synthetic? or should i put more miles on it then change. 2k f150 xtra cab 4x4 5.4l lariat</font>
the engine flush is for higher milage vehicles that might be sludged up, so that you can clean the inside of your engine before you switch.
I normally don't recommend an engine flush unless there are excess of 20,000 miles or higher.
Just go ahead and switch to full synthetic at your first scheduled oil changed(3,000) miles and you will be good to go.
Be sure to use a top quality filter like a Mobil 1, Purolator Pur 1, Amsoil SDF, or a AC Delco Ultra Gold.
Lube-Direct
New Lubrication Forums
