traction
Old Nov 19, 2000 | 04:29 PM
zoso's Avatar
Post traction
So I'm looking at getting a f-150 with the big 5.4 V8. The dealer let me take it off the lot alone, so I gave it the full workout. From a dead stop the wheels spun like crazy. How does the lightning (or any of you) get good acceleration from a stand still with no weight in the back end?
Old Nov 19, 2000 | 06:29 PM
max mitchell's Avatar
Cool
What was the year and tire condition? Was it a Limited-Slip rear end? My truck, if floored off the line, spins the tire about once, then takes off. It is a reg cab and not optioned out, so it is relatively light; it does have the LS rear though.
2000 F-150 XL, RC, LB, 5.4L, 4R70W, 3.55LS,
Class III tow, Payload #3, & Convenience pkgs.,
4-wheel disc/ABS, Chestnut/Parchment 40/60,
Ford bedliner w/Paintsaver & gas/wheel/spare locks,
Mobil 1, K&N oil filter, K&N F.I.P.K., Superchip,
Dynomax ultra-flow welded 3" cat-back w/ 3" Y-pipe,
Hellwig front & rear anti-sway bars, Rancho RS 9000s.
Old Nov 19, 2000 | 06:49 PM
Neal's Avatar
Cool
HI!... ZOSO : As you can see I have a slight traction problem with my 5.4!LOL!
http://www.fortunecity.com/silversto...s/freak1-1.jpg
http://www.fortunecity.com/silversto...s/freak1-2.jpg
http://www.fortunecity.com/silversto...s/freak2-1.jpg
http://www.fortunecity.com/silversto...s/freak2-2.jpg
http://www.fortunecity.com/silversto...s/freak2-3.jpg
http://www.fortunecity.com/silversto...s/freak3-2.jpg
Pis # 5 is about 1500ft of rubber layed down. JMC is the one taking the pictures. What can I say, I was installing new tires that day and figured I might as well have some fun with the old ones!LOL! To answer your traction question : Try not to step on the gas all the way when leaving a light. Just get it going as fast as you can with out tire spin and then nail it!
NEAL " THE H.P FREAK"
'99' F-150 XLT SPORT, oxford white, reg cab shortbox stepside,5.4, auto, 4.10L.S, captain's chairs, bedliner, GTS carbon fiber headlight covers, ***** CEPECK clear halogen driving lights, GTS slotted tailight covers (painted oxford white), fiberglass smooth wiper cowl (painted OXFORD WHITE), FORD locking lug nuts, tinted windows,true duel exhaust with 2.5 inch mandrel bent pipes and FLOWMASTER 3 chamber mufflers with 3' tailpipes exiting before the rear wheel like the LIGHTNING, HELLWIG rear stabalizer bar, 3 AUTOMETER guage pods, filled with tranny temp, engine temp, and oil preasure AUTOMETER "PHANTOM" guages,custom fabricated air intake trac and huge K/N filter, TPS mod, BELLTECH 2-inch rear drop, custom programed SUPERCHIP, BAUMANN ENGINEERING shift kit (on stage 5 setting)BYPASS CLUTCH CONTROL VALVE/PREASURE REGULATOR VALVE, ASP POWER PULLEYS, custom tig welded and ported JBA "JET BLACK coated headers, twin DERALE 16 INCH ELECTRIC FANS, PERMA COOL 14"/10" tranny cooler with 10" electric fan, custom ported (STOCK) throttle body, custom digital air intake temp sensor, custom ported TB intake elbow, relocated ATS.
FUTURE MODS : FORD SVT 24LB INJECTORS, CUSTOM SUPERCHIP FLIP-CHIP, BBK 75MM THROTTLE BODY, 80MM PRO-M MASS AIR METER, AADI F1 RAM AIR HOOD WITH CUSTOM FABRICATED RAM AIR SET-UP, CAL-TRAC TRACTION BARS, EXTRUDE HONED INTAKE MANIFOLD, SHM CUSTOM FUEL RAILS, SHM "RACE WATER PUMP, 90/10 FRONT CE SHOCKS, 70/30 REAR CE SHOCKS, BELL TECH 2/4 DROP, EXPEDITION CENTER CONSOLE, HARLEY DAVISON F-150, LOWER FRONT VALANCE (painted oxford white) and a KENNE BELL BLOWZILLA SUPERCHARGER.
ESTIMATED H.P TO DATE : 345H.P / 425ft/lbs of torque.
CURRENT PERFORMANCE : 1/4 MILE - 14.53E.T * MPH - 93.00 * 0-60MPH - 5.8 * 1/8 MILE - 9.2 * 60 FT - 2.0
OTHER TOYS : "83" PRO STREET FORD RANGER : 351-w stroked to 408c.i 625H.P (natural), 875H.P with 250H.P "BIG SHOT" N.O.S kit, tubbed (crome moly tubing), 12 point chrome moly roll cage, 4-link with coil overs, MUSTANG II front suspension, c-4 tranny (race prepped), 4000rpm stall converter(8 INCH), 3" chrome moly driveshaft,AUTOMETER guages, 15.50 MICKEY THOMPSON rear tires, 4" M/T front tires, CENTERLINE CON-VO PRO rims, fiberglass hood - bumper - prostock hood scoop, wishbone trac-link, two chrome moly driveshaft loops, 16 gallon RCI fuel cell,etc
