Engine block drain plugs
Old Nov 12, 2000 | 07:39 PM
moldmaker's Avatar
Post Engine block drain plugs
Has any one removed the two engine block drain plugs on a 4.6 with four wheel drive? These seem almost impossible to get at. The drivers side maybe the other one is under a motor mount bracket. If you did it how and what did you use?
David
