Why is the oil filter such a pain in the a$$?
Old Nov 8, 2000 | 11:21 PM
kkirt1's Avatar
Post Why is the oil filter such a pain in the a$$?
[whine mode=on]
Went to change the oil and filter on my new truck tonight. I had looked at the filter location and thought it would be more difficult then my '97 (it had the remote filter under the front bumper) but nothing I couldn't handle. Wrong! What a pain. Not only did the assembly worker torque it to what seemed like 200 ft/lbs but the location... what a joke!
Why did they get rid of the remote filter. That was such a great idea. Now, if you can get the stinking filter off, the oil drips down the plastic cover all night long!
[whine mode=off]
Supercrew 4x4 Lariat
Solid Black
5.4 Triton
3.55 Limited Slip
6750# GVWR Package
Skid Plates
Moon Roof
Sliding Rear Window
Trailer Tow - Class III
Cargo Cage
Grey Leather Captains Chairs
6-Disc CD Changer
Mods:
305/70/16 ATS, AR Atlas 16x8
Chrome Westin Steps
Planned: Dual Exhaust, Toneau Cover and Expedition Console Mod.
Another great Ford truck site -www.fseries.com
Truck Pictures
[This message has been edited by kkirt1 (edited 11-08-2000).]
Old Nov 9, 2000 | 01:00 AM
lightningcrashz's Avatar
Post
Its not that hard.I just drive mine to the shop and say change the oil.Really doesn't get any easier than that.I have a friend who has a f150 w/the 5.4 and he tried to change the oil and filter at 3,000 miles. he did manage to get it done but he has had the shop do it every time since then because it is a royal pain.
Old Nov 9, 2000 | 06:39 AM
black f150 offroad's Avatar
Post
i am the guy in the shop, belive me those are not the worst fords to change, try a sohc explorer, it sprays oil all over the lower contol arm and u get covered in the process, unless u have a brand new one as ford now angled the drain plug, keep complaining to ford and maybe they will bring back the remote filter, it will sure make my life easier
Old Nov 9, 2000 | 07:22 AM
ksdoxey's Avatar
Exclamation
I have to agree with blk150off**, i own both a 99 F150 5.4 and a sohc explorer and the F150 is a pain, but the explorer makes a complete MESS. It shoots oil out almost directly horizontal for the first few seconds. Just enough to coat the control arm and accessories... Then you have to wipe everything down....
WWWWWWWWWHHHHHHHHHAAAAAAAAAAAAAA!!!
Old Nov 9, 2000 | 07:35 AM
KT's Avatar
KT
Post
kkirt1, I know what you mean about that filter location. The first time i did it
it took 20min just to figure out where to
lay under there and how to get the filter
wrench on. Just did my third change two
weeks ago and only took about 5min to get
the filter off this time. Once you learn
the tricks it gets easier.
Old Nov 9, 2000 | 01:30 PM
flee's Avatar
Post
I have a question. Doesn't someone out there make a oil filter relocation product that we could use?
Thanks,
-ftlee
Old Nov 9, 2000 | 01:57 PM
Huckster's Avatar
Post
KT,
So what are the tricks? I have bought three different types of oil wrenches, each time hoping that it will make the job easier. I end up using my old wrench, but I can only turn it enough that I can see that it moved.
1. Loosen wrench
2. Reposition wrench
3. Barely move the filter
4. Cuss and swear at Ford
5. Repeat cycle
1999 XLT SC, 4x4, Long Bed, 4.6 with manual trans. Deep wedgewood blue
Old Nov 9, 2000 | 02:46 PM
lariat4wd's Avatar
Post
I think I saw a remote oil filter set up somewhere on the net. Try www.carparts.com or www.truckperformance.com Good Luck. I'm taking my in for it's oil changes...afterall, it's a lease anyway.
2000 Ford F-150 Super Cab Flareside 4x4 Lariat Black/Silver, 5.4L, 3.55LS, Off-Road, Class III tow pkg. So far, installed accessories included are: Lund X-Terminator bug shield, Vent Shade Vent Visors, GTS headlight blackouts, Westin Black nerf bars, Pendaliner bedliner...
Next on list:
GSP (Longtek Engineering) Grille/Brush Guard, roll bar, lots of lights, Optima red top battery, Kenwood TV/CD/AM/FM/DVD system, Viper alarm w/ remote start, Rancho RS9000s, custom tonneu cover to fit around roll bar, custom backup lights, and a boat to put behind it all. Please visit http://www.bmgsite.com and http://www.isurfwebdesign.com and http://www.bmgsite.com/truck or http://www.f150world.com/lariat4wd/ for truck pics.
Old Nov 9, 2000 | 03:30 PM
KT's Avatar
KT
Post
Huckster, The filter wrench i use is the flexable steel band type that swivels side
to side. I am not sure where i picked it up
at i have had it forever. You can only turn
it about 1/4 turn each time but once it
turns loose you can do the rest by hand.
When i go under the truck i go in head
first from the front laying next to the
tire, You will most likely have to use
both hands to get the wrench on because
of some sensor and wire right in the way.
I dont know if this helps any but its the
easiest way i have found.
Note: Your steps 1-5 will most likely
still apply.
Old Nov 9, 2000 | 03:58 PM
crash1's Avatar
Post
I change my own oil, and I do the filter by hand. if you need a filter wrench, the filter is too tight, or the gasket was not lubed. I never need a wrench for anything other than the drain plug. Just tighten the filter as tight as you can by hand.
On the Exploder and others where the oil comes out horizontally, take a piece of cardboard, bend it into a "V" shape, and use it to direct the oil into the drain pan. This also works with the filter.
BLOWN 4.6 5-speed
Where we started.
After a facelift.
Latest MOD!
Trixters-Playground!
trixters-playground@excite.com
F-150online Photo Album
crash@f150fanatic.com
MAGNACHARGER
ALLEN
Old Nov 9, 2000 | 04:07 PM
gofish's Avatar
Post
It's painfully obvious that you guys are bitchin' because you've never changed the filter on a Linc Mk8. The wrench barely fits. You can only crank it ~1/16 revolution from slap to slap before the handle hits some object. I guarantee you--if you overtighten, you're F**d the next time. It will leak half the filter's capacity even after waiting overnight. F*d On Raw Deal doesn't half explain Quality Job None, and yet it still beats any other US OEM.
Old Nov 9, 2000 | 07:48 PM
GIJoeCam's Avatar
Post
That cardboard trick for the SOHC explorers works like a charm... Buy a case of oil, and the box is good for at least 2 oil changes! :-) Works great! I think I get the suggestion from here, actually. :-)
-Joe-
98 Explorer (Lemon Law Case in Progress)
'00 F-150, X-cab, 4x4, Lariat, Off-road, Trailer Tow, Holandia Sunroof, built 11/99 picked up 10/00!
List of planned mods: Clear corners and tails, CB wiring, Stainless brush guard, at least 1 set of KCs (probably more!), custom radar detector mount, color matched trailer hitch with stainless steel ball, torsion bar tweak, bug deflector, spray in liner, and a tonneau of some sort...
Old Nov 9, 2000 | 09:47 PM
DiXie Truck's Avatar
Question
Why does ford keep changing the oil filter location just about every year? I have a 1998 4.6L engine and the oil filter is a breeze to change.
Old Nov 10, 2000 | 01:10 PM
gah's Avatar
gah
Smile
Amsoil makes an excellent bypass kit that allows you to run two oil filters in a remote location.
The great thing about this kit is that you can use any number of combinations of filters. The BE series will filter particles down to 1 micron compared to factory filters that at best filter down to 25 microns. I have the original kit, but the latest kit offers mostly cosmetic and mounting improvements. It sells for around $200.
'00 5.4L 4X4 Lariat (Black/Silver)
'99 Ranger 4.0L 4X4 XLT
Old Nov 10, 2000 | 07:40 PM
LARIAT1's Avatar
From: INDIANA,.....USA " Where more than Corn grows in Indiana"!!!
Thumbs up
Perma-Cool makes a great relocation kit. I have one on my truck. Cost was around $45.00 plus you use the full size Quart filter, like The FL-1A for more oil. My truck holds 6.5 Quarts now. But I went to the Ford Racing filter on my truck. The number is FL-1HP this filter costs more but is a better one in my book,Cost $10.00. The kit came from Jeg`s out of Ohio.
1997 Red/Silver F150 Lariat Flareside 3 Dr. SC..... ORP & Tow Package, Complete Lariat Option Package ,{APPEARANCE} GTS Projector Beam /Carbon Fiber Headlite Covers,AVS Tail Lite Slots & Door Sill Protectors,Flareside tail lites wired to work upper&lower lenses together,Owens Fg. Step Boards, Tinted Windows,Ford 2-Piece Bra,Lighted Ford Logo in Grill,20" Chrome Exhaust Tips,A.R.E Bed Cover Lid,Pendaliner Inner Tail Gate Protector,Zie-Bart Total Paint & Under Coating W/ Sounder Deadener Protection, Lariat #1 Plate under glass on Front Bumper,Custom made Ford Red Window Decals,Blue Tinted Rear Lic. Plate Protector,Blue Billet Valve Stem Caps, Ford Chrome Hitch Receiver Cover, HD Bed Mat, Red reflectors above Rear Bumper {PERFORMANCE} 4.6L WINDSOR Auto, 3.55LS, 4-Wheel ABS,Platinum 3 Spark Plugs,K&N Air Filter W/ modified stock MAF side air box,Outerwears Blue Pre-Filter Cover,Tornado Air Man.,Perma-Cool Oil Filter Relocation Kit,Motorcraft Racing Oil Filter FL-1HP,Dual Exhaust System W/Stock Muffler,NAPA Ceramix Carbon Ceramic Premuim Brake Pads(Front),Goodyear Wrangler A/TS Tires,55 Watt Halogen(replacement) Reverse Lites, Pilot 55 watt Halogen (add-on) Reverse Lites on Hitch under truck,Driving Lamps upgraded to 55 Watt Cool Blue Halogen Bulbs,Pilot Bright Whites headlite bulb replacements 65/55 watts,Driving Lamps(Foglites) work W/ High Beams On & Driving Lamps(Foglites) also work (ON or OFF) W/ Park Lamps On W/Switched Relay, A.R.E Cover wired W/interior(dome) light wired to a mounted door jam switch thats wired to hood light,SurgeGuard by Calterm {AUDIO} Stock In-Dash Cass. W/6 Disc Changer & 2 Stock Speakers(back) & 2 Pioneer TS-A6865 3- Ways(front),Black felted inner front door speaker openings , all speakers dynomat lined,Trenz Billet #3 Antenna {SECURITY} Ford Total Security System W/ Motion Alarm All on factory Key Fob,Ford Warning Decals on Windows,A.R.E Cover & Hood also wired to Alarm System, Hitch Pin locking system This is LARIAT#1..... IN The Great State Of Indiana "Where more than corn grows in Indiana".........http://hometown.aol.com/terrylariat1...page/auto.html A Very Proud Member of ...www.f150online.com
