Need 1/4 mile times
Old Oct 13, 2000 | 12:32 AM
Shortnugly's Avatar
Post
Andthenwhat??
Funny how you'd have to get a Ford V10 and chip it to beat the stock GM 8.1 V8.
That V10 was a real winner, see the other V10 threads in this board.
Can't resist that beautiful gravitational pull of those new GM engines.....
F150 is turning into F 1 outta here.
Old Oct 15, 2000 | 08:50 PM
Neal's Avatar
Cool
HI!... Well guys I ran a 14.72 E.T at 93 MPH at MILAN DRAGWAY yesterday. I was still spinning off the line a little bit and my dam "5284" error code showed up again causing throttle surges and bad idleing. If the weather was better and I could get really good traction I should be able to go 14.50's!!! By the way, this time was done with my STOCK 30 inch tall tires!!!LOL!
NEAL [ the horsepower freak ] NEWMAN
'99' F-150 XLT SPORT, oxford white, reg cab shortbox stepside,5.4, auto, 4.10L.S, captain's chairs, bedliner, GTS carbon fiber headlight covers, ***** CEPECK clear halogen driving lights, GTS slotted tailight covers (painted oxford white), fiberglass smooth wiper cowl (painted OXFORD WHITE), FORD locking lug nuts, tinted windows,true duel exhaust with 2.5 inch mandrel bent pipes and FLOWMASTER 3 chamber mufflers with 3' tailpipes exiting before the rear wheel like the LIGHTNING, HELLWIG rear stabalizer bar, 3 AUTOMETER guage pods, filled with tranny temp, engine temp, and oil preasure AUTOMETER "PHANTOM" guages,custom fabricated air intake trac and huge K/N filter, TPS mod, BELLTECH 2-inch rear drop, custom programed SUPERCHIP, modified POWERAID spacer, BAUMANN ENGINEERING shift kit (on stage 5 setting)BYPASS CLUTCH CONTROL VALVE/PREASURE REGULATOR VALVE, ASP POWER PULLEYS, custom tig welded and ported JBA "JET BLACK coated headers, twin DERALE 16 INCH ELECTRIC FANS, PERMA COOL 14"/10" tranny cooler with 10" electric fan.
FUTURE MODS : FORD SVT 24LB INJECTORS, BBK 75MM THROTTLE BODY, AADI F1 RAM AIR HOOD, traction bars, and a KENNE BELL BLOWZILLA supercharger.
ESTIMATED H.P TO DATE : 345H.P / 425ft/lbs of torque.
OTHER TOYS : "83" PRO STREET FORD RANGER : 351-w stroked to 408c.i 625H.P (natural), 875H.P with 250H.P "BIG SHOT" N.O.S kit, tubbed (crome moly tubing), 12 point chrome moly roll cage, 4-link with coil overs, MUSTANG II front suspension, c-4 tranny (race prepped), 4000rpm stall converter(8 INCH), 3" chrome moly driveshaft,AUTOMETER guages, 15.50 MICKEY THOMPSON rear tires, 4" M/T front tires, CENTERLINE CON-VO PRO rims, fiberglass hood - bumper - prostock hood scoop, wishbone trac-link, two chrome moly driveshaft loops, 16 gallon RCI fuel cell,etc
Old Oct 16, 2000 | 10:16 AM
just me's Avatar
Post
Neal,
just wondering if you have any 1/4 mile times from when you were still stock? Do you have any numbers for each mod as it was added?
Old Oct 16, 2000 | 02:27 PM
Neal's Avatar
Cool
HI!... JUST ME : When I 1st ran my truck at the dragstrip it was'nt stock. The only mods I had done to it were 4.10 gears and a custom made air intake trac with a 14 inch long K&N filter. The truck ran a 16.00E.T. It was about 95 degree's outside with a ton of humidity. Because of the 4.10 gears I was banging off the 1st to 2nd gear rev limiter so HARD that it almost stalled the truck while going down the 1/4 mile! Then I put my SUPERCHIP back in the computer and ran a 15.68E.T, but I was still hitting the 1st to 2nd gear rev limiter really hard! The next time to the track I had a custom SUPERCHIP burned for my 4.10 gears. It was just as hot as the 1ST time and I ran a 15.39E.T. That E.T was with me burning the tires off all the way through 1st gear! So as you can see I knocked off 6.1 TENTHS just with the SUPERCHIP! Then I knocked off another 6.7 TENTHS with the installation of ASP power pulleys, custom ported JBA headers, DERALE twin electric fans, BAUMANN ENGINERING shift kit on stage 5, and a relocated ATS. I still have to install 24lb injectors, ram air hood with functional ram air box, 75mm BBK throttle body, maby a PRO-M mass air meter and was thinking of getting my intake extrune honed. Then I want to see if I can get some M/T SPORTSMAN PRO tires so I can get some traction!LOL! My goal of getting into the 14's has been acheived, so now my goal is to go 13.99E.T naturally asperated!
