antifreeze smell
Old Jan 28, 2002 | 05:01 PM
ansky's Avatar
antifreeze smell
some times after i park my truck i can smell antifreeze. i can see the fluid level has not moved in the over flow tank and i cannot find any evidence of leaking anywhere.i have traced every line from the radiator and the water pump and still have found nothing leaking,this is really frustrating,has any one had this problem on a 4.2 litre and found the cause? also checked oil it is not milky ao anything. thanks
Old Jan 29, 2002 | 10:18 PM
Ron Midura's Avatar
Yeah, I have the same situation in mine, but I have the 4.6.
Old Jan 30, 2002 | 07:20 AM
Pickup Man's Avatar
Check your heater hoses. In my opinion, what you are smelling is probably your hoses gettign weak, and then evaporating from the heat of the engine, and you aren't losing enough to tell that you are losing antifreeze. Also, may be related to the water pump, if it leaks at all, it could cause the antifreeze to heat up, and you would smell the evaporation of it, too. Maybe even a thermostat. Just some ideas, I am by no means an expert on this. Anyone else wanna take a stab?
Old Jan 30, 2002 | 05:58 PM
SigShooter's Avatar
I too had an antifreeze smell in my truck last year. I looked all over until I found a small amount of coolant in the valley of the engine. It turned out to be intake manifold gaskets. They were replaced at the dealer, cost around 300.00 dollars. No leaks since. I have a 97 4.6.
