Oil Leak (front of block)
Old Jul 28, 2000 | 06:46 PM
Jim Mc's Avatar
Red face Oil Leak (front of block)
I have discovered an oil leak from the front of the engine block. After doing a search on oil leaks, I see that a common problem is oil leaking from timing cover. Where is this located? Mine seems to be comming from the center front of the block (crank seal?)There is evidence of oil on the bottom half of the block and down over (under) the oil pan.
My truck is at the dealer now but I just wanted to see if anyone else had a (crank) seal leak. comments?
Pinckney Pirate
[img]//pinckneypirate.homestead.com/files/pirateflag.gif[/img]
http://pinckneypirate.homestead.com/index.html
98Lariat 5.4 4X4 SC SB Tow ORP
Superchipped!
K&N
WMS Velocity tube
Gibson exhaust
Edelbrock IAS
JBA Headers
Clear front corners
16X8 Centerline Billet Wheels 285 75 16 BFG AT's
Do it inna dirt!
jimmac@ismi.net
[This message has been edited by Jim Mc (edited 07-29-2000).]
Old Jul 28, 2000 | 10:10 PM
98SCREAMER's Avatar
From: Houston, by way of every major city in America.
Red face
I had the same problem with my 98, They found
it just before the warranty ran out. I took it
in for front brakes but they found that and the power steering were leaking . They fixed
all three things in two days,but they left some bolts loose. These were on the p/s pump.
I hope there are not any more loose too.
Just a warning,,don't take your truck to earnhardts ford in Tempe AZ.
Old Jul 29, 2000 | 07:19 AM
Jim Mc's Avatar
Post
Thanks Screamer, I know what you mean about dealer service dept. This will be the third different dealer that I am trying!
