How to hop up a 93 302?
Old Jul 27, 2000 | 02:25 AM
j.deka's Avatar
Question How to hop up a 93 302?
So far I've put Hypertech pulleys and Gibson exhaust (the one that goes out the side) on there. One of the lifters is going bad, and since it needs replacing anyway, I was wondering if I should just buy one of those high-perf cam and lifter kits. Will that help on power? Or any other suggestions? Also, a friend gave me a custom chip for his 94 Lightning. But I figure my tranny isn't up to it. Anyway, new to this board, like what I see.
Old Jul 27, 2000 | 09:08 AM
Jason Zaluski's Avatar
Post
j.deka: That chip your friend gave you won't work in your truck... the L has a 351, not a 302. If you want a chip, the chip to get is a Superchip from Mike Troyer. He's here on this board a lot.
You can get tons of power out of these 302s... you just have to set a price range. Heads, Intakes, Rockers, Cam... there's a lot of things you can do.
The big question before you start moding however, is do you have mass-air or speed density?
1995 F-150 Regular Cab Flareside w/ 302 V8... Mods: Mass Air, K&N FIPK, Dual Exhaust (no mufflers), Lund Premier Tonneau Cover, Motorsports 9mm Plug Wires, full JL/Kicker/Pioneer system, Autometer 5" tach, Superchip, Precision Gear 3.73s, TD Chrome Diff Cover
Best 1/8th ET: 10.4107 @ 65.9587 MPH
The F-150 Resource Guide
The F-150 Resource Guide-- a site dedicated to 1987 through 1996 F-series trucks.
Old Jul 27, 2000 | 10:25 AM
Matt90GT's Avatar
Post
The biggest restriction on the 302s is the heads. If you want the most power for the money, look into a good set of aftermarket heads.
Old Jul 28, 2000 | 10:41 AM
T Ellenberger's Avatar
Post
Buy a stroker kit and make the 302 a 347 or replace it with a 351. Sounds extreme but a lot of improvement at one time.
97 F-150, 2WD, Reg Cab,Flareside,Dk Toreador Red, Windsor 4.6, Magnecor 8.5mm wires, Bosch Plat +4s, 3.55 LS, EGR Bug Deflector, ******* Bed Cover, Bed Liner, XL Full Length Running Boards, Air Aid Kit, Gibson Single Out Cat Back, Superchips, TransGo Shift Kit, Hellwig Rear Sway Bar, Hellwig 2500# Overload Springs,Energy Suspension Polyurethane Front Sway Bar Bushings, 265 70 16 tires, Rancho RS9000 shocks
Old Jul 28, 2000 | 10:58 PM
powerlifter405's Avatar
Post
Summit catalog,
Trickflow TW-heads, TF upper and lower intake, and a good cam. Combined with making sure all your intake is opened up to about 70 mm or so. With this set up you'll need to turn your fuel pump up.
"a 351 windsor 1969 C90E block (9.48 deck height) .030 over, .010/.010 under stock crankshaft, 5.95(stock length) rods, SRP/JE flattop pistons. Cam at 220*/228* at .050 and .542/.563 lift at the valve w/ 1.6 roller rockers.
This equated to 344.5 rwhp and 372.1 ftlbs.
403/435 at the flywheel.
This was w/ the Trick flow heads and intake.
Good luck.
BTW. for about 1700, the heads and intake and a cam on your 302 will equate to about 325hp, from all my past calculations.
The throttle bodies and egrs etc... won't make too much extra power but will help it flow freeier and let the power come on "easier".
Old Jul 29, 2000 | 12:56 AM
Pastmaster's Avatar
Post
Becareful what you do with your speed Density efi system. It limits alot of performance.
You can still get alot of power out of the 5.0L. To me, its a misjudged engine. Ever wonder why so many Mustang's used it?
Jason's got 7.5 second's from his 5.0. I'll bet a 5.8L can't do much better if at all.
The stroked 5.0 is a cool idea. But it wouldn't last any time.
The motor is bored .30 over and has a 3.40" stroke. I believe it puts out over 300hp though.
"Sleeper"
1993 F-150 5.0L/e4od/355LS. Dual exhuast w/o mufflers, 2 1/4" pipes, Echo Tips, Summit Racing headers, MSd Wires/Motorcraft Plugs, hypertech powermodule, 4 degree advance,Blaster Coil,MSd 6A Ignition, TPS Mod,5% dark tint, Ford Bed mat, Bundy Chrome Drop bumper, Wrap-around bug deflector, 2-tone tan/brown. Alpine cd player and Pioneer speakers, with tweeters
"Sleeper"
1989 F-150 XLT 4x4 302/Aod MM hubs, true duals with turbo mufflers, maroon/grey middle,
Future H-D 1200 Sportster owner
[This message has been edited by Pastmaster (edited 07-29-2000).]
