Back again with Jacobs info
Old Jun 18, 2000 | 11:10 PM
  #31
WLF's Avatar
WLF
Cool
Ok, just finished the second tank full TRYING to not get into the right peddle too much. I can say for sure I am getting at least 10% better mileage. Since changing my tires from 235/16 to 265/17 my milage per tank has been about 290. Its actually more since the speedo is off. The last two tanks have given me 322 and 325 before the red "low fuel" light came one. I have not gotten over 300 since changing the tires. Also I have to admitt that even on these tanks, I've gotten into the throttle more then once.
Black 1997 F-150 Supercab Flairside. 4.6L with Jocobs DIS, K&N Generation II, Cat back Exhaust (my own, nice rumble). 17" Off Road wheel pkg. Lots of body mods. 4 yrs old and still turns heads...
Old Jun 19, 2000 | 07:06 PM
  #32
doorslammer69's Avatar
Post
WLF: Had the plugs changed today. Accel coil packs arrived today, but one was broken & I have to send it back..Stay tuned...Mark.
Old Jun 20, 2000 | 01:44 AM
  #33
powerlifter405's Avatar
Post
Why the jacobs and accel coil pack together.
Are these on the same vehicle?
I guess i;m missing something?
Old Jun 20, 2000 | 09:29 PM
  #34
Post
Jacobs recommends em--hotter spark yet.
Old Jun 20, 2000 | 11:56 PM
  #35
Post
I still don;t understand. Where/what does the jacobs get hooked to , compared to what the accel does.
Dr.(wife says i'm spoiled) Jones.
5.4L(whatpowerawaitsthee)
AUTO,SC4x4 anniversary gift. PSD coming for christmas!
djones01@elp.rr.com
Old Jun 21, 2000 | 06:39 PM
  #36
Post
The Jacobs unit connects this way: Power to the unit is supplied by the vehicles battery. Each coil pack cable coming off the unit has two plugs. One plug connects to the plug that would normally connect to the coil pack. the other plug connects to the coil pack itself. Jacobs unit supplies a hotter, multiple spark over more degrees of crankshaft rotation than the stock unit. The Accel coil pack should make that spark even hotter. Will let everyone know results...Mark
Old Jun 22, 2000 | 12:57 AM
  #37
Post
DS69, where did you get the Accel unit from and how much damage$$$?
I'm really considering the Jacobs unit. I just realized that over each plug there is a factory cogswell cog, or spacely sprocket
and there appears to be no coil.
Money saved??
djones01@elp.rr.com
Old Jun 22, 2000 | 02:11 PM
  #38
WLF's Avatar
WLF
Cool
Powerlifter,
Those Cogswell Cog's are coils, one for each cylinder.
By the way, if you get that thing flying, say hi to George for me...
Old Jun 22, 2000 | 11:50 PM
  #39
Talking
George says hi, so does elroy and jane!
does each one get replaced w/ an accel unit?
AUTO,SC4x4 Airbox silencer removed/K&N, Amsoil, 3" custom dynomax ultra flow catback, as an anniversary gift. PSD coming for christmas!
djones01@elp.rr.com
Old Jun 29, 2000 | 01:44 AM
  #40
outplaying's Avatar
Question
WLF and Doorslammer,
where do you have your Jacobs installed? About the only place I can find to fit it is behind the grill like they suggest. I am soon going to a place where it is very hot, and don't want to cover up the radiator any more than I have to. Thanks
98 XLT SC Flareside 4.6, 3.55LS, ORP, loaded (no leather), chrome Smittybilt Outland, 2 KC Daylighters (stainless), chrome diff cover, Ventshades, catback duals, Alpine CDw/Alpine 6-disc changer, Air Raid FIPK, 3" Body Lift, 33" Super Swamper SSRs on Centerline HTII Rims
Westin Nerf Bars (already dinged )
SplitFire Plugs and Motorsport 9mm Wires: www.mwr.is/~outplayn/Ford.html
REPLACED DRIVERS SIDE TORSION BAR
DRIVERS SIDE DOOR CRACK
(FIXED)LEAKING REAR WINDOW
REPLACED WINDSHIELD (TWICE)
STUCK ODOMETER
GRINDING STARTER
VARIABLE WIPERS (THEY VARY ALL BY THEMSELVES)
BROKEN WHEEL STUDS
ALL THIS AND MORE, AT 29K MILES.
WHAT A BARGAIN!!!!
STILL LOVE IT
COMING THIS YEAR: Icelandic Fender Cutouts and Flares, 38" Tires on Beadlocked rims, and 4.88 gears. WITH NO SUSPENSION LIFT
"The never ending project truck"
Old Jun 29, 2000 | 11:56 PM
  #41
Flats Man's Avatar
Cool
Jacobs Gas Milage-I just arrived in Texas from Florida and have some gas milage figures since the Jacobs install. On the first tank, which included about 45 minutes of city driving, I got 17.7mpg driving around 75mph no cruise control. This also included dusting a Mercedes ML 320 from a light. The second tank was a "Cannon Ball Run" with speeds of 95+ and rarely slower than 80mph. This was a fast crowd in a hurry! Anyway I got 16.9 on that tank. The last tank I got a reading on was on the freeway at 75 mph with cruise control on and I got 18.5! I feel the claim of 10% fuel milage increase is a very solid claim and the truck performed flawlessly all the way. I hope this info is of use to those thinking about upgrading you ignition systems in the future.
98 White 4.6 Triton STX Flairside,Class III hitch, Blue Cobra Stripes, Euro Lid by Astro, Bed Rug, Fiero Wing, Air Dam,Westin Step Bars, Ground Force 2-4 Drop, Super Chip,Jacobs DIS Ignition, B&M Shift Kit, K&N, Jet coated JBA stainless headers, Magna Flow Muffler with Stainless Duals.
Old Jun 30, 2000 | 10:43 AM
  #42
97lariat2wd's Avatar
Post
Just curious as to the spark plug gap that everyone used??? And by the way you can mount the DIS computer where the Windshield washer resivour is. Just remove the resivour, and mout it to the front side of the engine compartment.
Old Jul 1, 2000 | 01:53 PM
  #43
Post
Jacobsa unit hangs from radiator brace behind grill..Hotter than hell here in south florida--no problems--still don't have 2nd accel coil pack.
Old Jul 1, 2000 | 05:58 PM
  #44
Boss96Hog's Avatar
Post
DoorSlammer
Where in S. FL??? Pompano Beach here
Old Jul 1, 2000 | 11:27 PM
  #45
WLF's Avatar
WLF
Exclamation
I actually put mine on top of the fan shroud on the right (passenger) side with two of the mounting holes using the push thru connectors that hold the cover on. The third hole was drilled thru just over and forward of the fan itself. The 4th hole is in the air and now being held with a bracket I made that connects back to the fan shroud. This position puts it up where it can be seen and it is a cooler place then next to the radiator. I too continue to get better milage and strong pulling especially under mid rpm, high torque conditions (like passing and towing).
