fuel systems 2
Old Jun 29, 2000 | 09:38 AM
taptones's Avatar
Question fuel systems 2
I am having a problem with my 87 F150. In every gear the truck is kind of sluggish until it hits the 2000-2500 RPM range and then it takes off. Could this be a clogged catylytic converter? Any help would be appreciated!
Old Jun 30, 2000 | 03:48 PM
max mitchell's Avatar
Question
A clogged converter would run worse the higher the rpms, not the reverse, because it fills up with more combustion. Sounds like a fuel or ignition problem. Sounds more like a ignition problem. Have you checked your plugs? That's a good place to start. Plug wires, distributor advance, etc.
2000 F-150 XL,RC,LB,5.4,4R70W,3.55LS,
Class III tow/Payload #3/Convenience pkgs.,
4-wheel disc/ABS,Chestnut/Parchment 40/60,
Ford bedliner & gas/wheel/spare locks,
3" cold air box modification,Superchip,
Dynomax ultra-flow welded 3" cat-back.
