governed 4.6
just wanted to flatline my truck one day on the strip and find out that I can,t get it up above 96 mph.Is there a problem or is the engine governed? Does anyone else have the same problem?
RESTRICTED
RESTRICTED
Yes, there is a top speed limiter. I don't know what your truck type is, but my top speed limiter was 98 mph. My factory tires aren't rated much above this either. There were many reasons why I added a superchip, and one was to remove the top speed limiter completely. As soon as the first tires wear out, I'm going to get higher top speed rated tires.
2000 F-150 XL,RC,LB,5.4,4R70W,3.55LS,
4-wheel disc/ABS,Chestnut/Parchment,
Ford bedliner & gas/wheel/spare locks,
3" cold air box modification,Superchip,
Dynomax ultra-flow welded 3" cat-back.
I only had mine as fast as 95 so far I have no idea what my speed limiter is set at if it wasn't for the high price of gas I to would have a super chip to remove it just to go 100 plus every now and then.
2000 F150 XLT Reg. cab
4.6 Triton Engine
4x2 3.55 rear end gear
sliding rear window
automatic keyless entry
white styleside short box
4.6 Triton Engine
sliding rear window
