O2 sensor (check engine light)
Old Aug 12, 1999 | 08:11 PM
Squanto804's Avatar
Unhappy O2 sensor (check engine light)
My check engine light came on and had a local shop read the code. The code was PO141
(Downstream heated 02 sensor heater circuit fault-bank 1) I assumed it was a bad sensor-I spent $75 on new sensor- again I assumed "downstream" meant the sensor past catalytic converter and "bank 1" meant left side? Anyway,the new sensor did not help. Very frustrated. Did I assume right and any ideas would be apprieciated. Thanks
Old Aug 13, 1999 | 10:16 AM
Tina's Avatar
Lightbulb
Call the Ford service dept and ask them what it means. Then fix whatever it is that they say is the problem.
Old Aug 13, 1999 | 11:28 PM
Squanto804's Avatar
Post
Well Tina, I already tried that...and as usual, my local Ford dealer was NO help. They needed the truck to tell, even though I already had the code and I'm sure not going to dish out $60 to have them tell me what I already knew and another $150 to fix it.
But anyways, I figured out that "Bank 1" is on the right side of the engine. I put the sensor on the wrong side...duh. Fixed it and no problems so far.
Old Aug 14, 1999 | 11:22 AM
Tina's Avatar
Thumbs up
Good for you, I to am no fan of the "service dept" but was hoping you might have a good one where you live. (I've heard there really are some) Glad you got it fixed.
Old Mar 29, 2000 | 04:58 PM
Xenon's Avatar
Post
GREAT_ I had the same code error number " po141"-- bought a 02 sensor from napa "bosch 64 $bucks. My Mechanic said bank 1 was driverside-- but after reading this board i knew he was wrong, ITS passanger side!!
changed out sensors and walla!! after 3 short trips the "check engine" light put itself out!.
THANKS!
97F150/xlt/Blk/FLARED/regcab/auto/4x2/4.2/k&n/40flowmaster/Xenon H.I.D..
