o.K. to start using synthetic oil at 32,000miles??
Yes it is fine to start using synthetics now.
I would do an engine flush before you switch over to clean out any of the deposits that have formed from the conventional stuff. I would imagine that any parts store carries some type of engine flush that you put with the old oil and run the engine for a few minutes then drain it all out.
Read the directions.
(Doing this prevents your new clean filter from prematurely clogging because of the cleaning properties of synthetic oil)
http://www.exxon.mobil.com/mobil1_ra...oil/index.html
Once you do this you are good to go. I would also recommend using a top quality filter, either Mobil 1 or Amsoil or Pure 1.
Good luck.
Lube-Direct
New Lubrication Forums
Good luck.
Lube-Direct
